coq-club - Re: [Coq-Club] matching evaluation
chronological Thread
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] matching evaluation
  • Date: Sat, 09 Jan 2010 09:16:34 +1000
Hi Flávio,
You wrote:
> Fixpoint prod_in (n m:nat) {struct m} :=
>   match n with
>     | 0%nat => 0%nat
>     | S j =>   match m with
>                  | 0%nat => 0%nat
>                  | S i =>
>                    match (le_gt_dec i j) with
>                      | right _ => mult m (prod_in n i)
>                      | _ => m
>                    end
>                end
>   end.
In this case, you can lift the non-recursive parameter outside the
recursive definition:
Definition prod_in (n: nat) : nat -> nat :=
  match n with
    | 0 => fun m => 0
    | S j => fix p m :=
      match m with
        | 0 => 0
        | S i =>
            | right _ => mult m (p i)
            | _ => m
          end
      end
  end.
Then Coq should perform the reduction you expect.
Regards,
Matthew
