- From: Fl�vio Leonardo Cavalcanti de Moura <flaviomoura AT unb.br>
- To: coq-club AT inria.fr
- Subject: [Coq-Club] matching evaluation
- Date: Fri, 08 Jan 2010 11:48:36 -0200
Hi there,
I defined the following recursive function:
Fixpoint prod_in (n m:nat) {struct m} :=
match n with
| 0%nat => 0%nat
| S j => match m with
| 0%nat => 0%nat
| S i =>
match (le_gt_dec i j) with
| right _ => mult m (prod_in n i)
| _ => m
end
end
end.
As expected
"Eval compute in (prod_in 0 1)" returns 0, but if I declare a variable m
of type nat
"Eval compute in (prod_in 0 m)" doesn't evaluate to 0. In fact, Coq
returns
= (fix prod_in (n m : nat) : nat :=
match n with
| 0%nat => 0%nat
| S j =>
match m with
| 0%nat => 0%nat
| S i =>
if (fix F (n0 : nat) :
forall m0 : nat,
{(n0 <= m0)%nat} + {(S m0 <= n0)%nat} :=
match
n0 as n1
return
(forall m0 : nat,
{(n1 <= m0)%nat} + {(S m0 <= n1)%nat})
with
| 0%nat =>
fun m0 : nat => left (S m0 <= 0)%nat (le_O_n
m0)
| S n1 =>
fun m0 : nat =>
match
m0 as n2
return
({(S n1 <= n2)%nat} + {(S n2 <= S n1)%
nat})
with
| 0%nat =>
right (S n1 <= 0)%nat
(gt_le_S 0 (S n1) (lt_O_Sn n1))
| S m1 =>
match F n1 m1 with
| left a =>
left (S (S m1) <= S n1)%nat
(gt_le_S n1 (S m1) (le_lt_n_Sm n1
m1 a))
| right b =>
right (S n1 <= S m1)%nat
(gt_le_S (S m1)
(S n1) (le_lt_n_Sm (S m1) n1
b))
end
end
end) i j
then m
else
(fix mult (n0 m0 : nat) : nat :=
match n0 with
| 0%nat => 0%nat
| S p =>
(fix plus (n1 m1 : nat) : nat :=
match n1 with
| 0%nat => m1
| S p0 => S (plus p0 m1)
end) m0 (mult p m0)
end) m (prod_in n i)
end
end) 0%nat m
: nat
I see no reason to explain why the first match (the most external one)
cannot be solved, once n is 0 in this case. Could it be related to the fact
that the recursive argument is the second one?
Cheers,
Flávio de Moura.
- [Coq-Club] matching evaluation, Flávio Leonardo Cavalcanti de Moura
- Re: [Coq-Club] matching evaluation, Adam Chlipala
- Re: [Coq-Club] matching evaluation, Matthew Brecknell
