coq-club - [Coq-Club] Windows binaries for Coq 8.2pl1 + ssreflect 1.2 + Heq 0.9
chronological Thread
  • To: <coq-club AT inria.fr>
  • Subject: [Coq-Club] Windows binaries for Coq 8.2pl1 + ssreflect 1.2 + Heq 0.9
  • Date: Tue, 26 Jan 2010 18:23:08 +0100
Dear coq-users,
I compiled Coq 8.2pl1 + ssreflect 1.2 + Heq 0.9 together in Windows.
Even when you have trouble with compiling ssreflect 1.2, you can use these binaries (coqtop.opt.exe & copide.opt.exe).
WARNING: This is only for Windows users.
1. Download the above file and unzip 'Heq-0.9.zip' and overwrite your 'coqtop.opt.exe' & 'coqtop.exe' with 'Heq-0.9/winbin/coqtop.opt.exe'.
   If you use coqide, overwrite your 'coqide.opt.exe' & 'coqide.exe' with 'Heq-0.9/winbin/coqide.opt.exe'.
2. If you want to install Heq 0.9, then see 'Heq-0.9/INSTALL'.
If you want to install ssreflect 1.2,
3. unzip 'ssreflect-1.2.zip' and go to the directory 'ssreflect-1.2' and delete the following two lines in the file 'Make'.
    -custom "$(COQBIN)coqmktop -opt -o bin/ssrcoq src/ssreflect.cmx" "src/ssreflect.cmx" bin/ssrcoq
    src/ssreflect.ml
4. and change
    SSRCOQ = bin/ssrcoq
    to
    SSRCOQ = coqtop.exe
    in the file 'Make'.
5. execute the following three commands.
    coq_makefile.exe -f Make -o Makefile
    make
    make install
Cheers,
Chung-Kil Hur
