coq-club - Re: [Coq-Club] inductive types and well-foundness of the structural orderings
chronological Thread
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] inductive types and well-foundness of the structural orderings
  • Date: Thu, 28 Jan 2010 03:13:32 +0800
Hi Gyesik and Matthieu,
Consider the following proof for your goal:
Theorem le_Pfact: forall x:nat, exists y, Pfact x y.
Proof.
fix circ 1.
intro.
destruct x.
exists 1.
constructor.
destruct x.
 exists 1.
 constructor.
 pose proof (circ x) as H.
 destruct H. (* existential var becomes x0 *)
 exists (x * x0).
 constructor.
 assumption.
Save.
I find the above style of inductive proof much easier. Of course, the hypothesis "circ" must be applied in a well-founded way. However, there's no need to have an adequate induction principle readily available (or even bother to know what that induction principle should be).
Hope this helps,
Razvan
Matthieu Sozeau wrote:
Le 27 janv. 10 à 10:57, Gyesik Lee a écrit :
Hi,
Hi Gyesik,
as in the following case, an induction principle provided by Coq is
sometimes not strong enough:
(A  modified version of the example in Section 8.4.1.1 of CoqArt book.)
Open Scope nat_scope.
Inductive Pfact : nat -> nat -> Prop :=
| Pfact0 : Pfact 0 1
| Pfact1 : Pfact 1 1
| Pfact2 : forall n v : nat, Pfact n v -> Pfact (S (S n)) (n * v).
Axiom lt_wf : well_founded lt.
Theorem le_Pfact : forall x : nat, exists y, Pfact x y.
induction x.
(* then the induction hypothesis is not strong enough*)
Abort.
induction x using lt_wf.
(* then the claim can be easily proved. *)
I am wondering if Coq provides a kind of mechanism producing the
induction principle reflecting the well-foundedness of the canonically
definable structural orderings on inductive types.
My soon-to-be-released Equations [1] plugin has ML code to generate this
order on any non-impredicative, computational inductive family (ie. most
datatypes). You can derive both the subterm relation (actually the
transitive closure of the direct subterm relation) and its wellfoundedness
proof and a [Below] predicate that can be used to recurse and get a tuple
of all the possible recursive calls in the context. You don't need to worry
about guardness checks anymore if you use any of these, but you have to
provide proofs that recursive arguments decrease in the first case or
find your way in a tuple in the second case. This is partially automatable
though.
Require Import Equations.
| Pfact0 : Pfact 0 1
| Pfact1 : Pfact 1 1
Derive Subterm for nat.
apply FixWf; intros.
destruct x. econstructor; constructor.
destruct x. econstructor. constructor.
  destruct (H x). solve_rec.
  exists (x * x0). constructor; auto.
Qed.
Derive Below for nat.
Definition rec_nat (P : nat -> Type) (step : Π n, Below_nat P n -> P n) n : P n :=
  step n (below_nat P step n).
Theorem le_Pfact' : forall x : nat, exists y, Pfact x y.
induction x using rec_nat.
  simpl in X. destruct_conjs.
  exists (x * e0). constructor; auto.
Qed.
[1] http://mattam.org/research/coq/equations.en.html
-- Matthieu
