coq-club - Re: [Coq-Club] inductive types and well-foundness of the structural orderings
chronological Thread
  • To: AUGER <Cedric.Auger AT lri.fr>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] inductive types and well-foundness of the structural orderings
  • Date: Thu, 28 Jan 2010 23:49:01 +0800
Hi Cedric,
You are right. However, I think using 'fix' is a matter of preference after all. It is indeed unsound from a pure sequent-calculus point of view, but in Coq the 'Guarded' command comes to the rescue, telling the user if the type checker detects unguarded applications of the "unsound" hypothesis up to the current point in the proof (one major disadvantage is that you can't employ the automated tactics while the unsound hypothesis is present in the current sequent, you must clear it first).
I would actually appreciate a (yet another unsound) tactic that would allow me to create mutually recursive 'fix' constructs.
Here's another little gem using 'fix' :
Inductive even : nat -> Prop :=
 e0 : even 0
| eS : forall n, even n -> even (S (S n)).
Goal forall n, even n \/ ~ even n.
fix circ 1.
intros [|[|n]].
left ; constructor.
right ; intro H ; inversion H.
assert (H := circ n) ; clear circ.
destruct H.
left ; constructor ; assumption.
right ; intro H1; apply H ; inversion H1 ; assumption.
Save.
Razvan
AUGER wrote:
As far as I know, fix tactic is just
fix a n.
"refine (fix a {struct nth_term} := _)."
or something like that,
 that is you will have a "a: [Goal]" in your hypothesis,
 which you will able to use at any time.
 This feature is in fact inconsistant, try:
Lemma Absurd: False.
Proof.
 generalize tt.
 fix dummy 1.
 assumption.
Qed.
Hopefully type checking denies this proof, but you found a "Proof completed."
before Qed, meaning that you proceded without guardedness.
For huge proofs, it can be a pain in the neck to correct it.
In fact some interesting feature would be to print a new kind of hypothesis
only available for information (not usable) and generate an hypothesis each time
the main term is destructured.
For example:
Theorem le_Pfact: forall x:nat, exists y, Pfact x y.
Proof.
 intro; new_induction x.
  exists 1; constructor.
 destruct x.
 destruct Hx0 as [y P]; exists (x * y); constructor.
 exact P.
Qed.
would have the following execution:
Proof.
______________________________________(1/1)
forall x : nat, exists y : nat, Pfact x y
______________________________________(1/2)
exists y : nat, Pfact 0 y
(* Hxn : exists y : nat, Pfact xn y [where xn is a subterm of x]*)
x : nat
Hx : exists y : nat, Pfact x y
exists y : nat, Pfact (S x) y
 destruct x.
Hx : exists y : nat, Pfact 0 y
exists y : nat, Pfact 1 y
x : nat
Hx : exists y : nat, Pfact (S x) y
Hx0 : exists y : nat, Pfact x y
exists y : nat, Pfact (S (S x)) y
x : nat
y : nat
P : Pfact x y
Pfact x y
 exact P.
Proof completed.
Qed.
If the above is unreadable, try:
Ltac new_induction x :=
 destruct x; [|assert (Hx:exists y, Pfact x y);[admit|]].
Ltac new_destruct x :=
 destruct x; [|assert (Hx0:exists y, Pfact x y);[admit|]].
Proof.
 new_destruct x.
 exact P.
Qed.
to understand what I mean
(it is a simulation of the feature, in real tactics,
 we don't want to use "admit").
One last thing about recursion, but it is out of topic,
as far as I know, we have no way to indicate the decreasing
argument in:
Lemma A: ...
with B: ...
For that I have to do:
Lemma A: ...
Proof.
 refine (fix A: ... {struct ...} := _
         with B: ... {struct ...} := _
     for A).
(*lemma A*)
(*lemma B*)
Which can be syntactically awfull, and produces a proof of A and none of B.
Not giving the decreasing argument can lead in way too long computation to
determine which one to choose and only few seconds if we indicate it directly.
I have once met this problem.
I know there may exist some solutions with Program or Induction Scheme,
but for such low level things, there should exist simple ways to do it.
