- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] inductive types and well-foundness of the structural orderings
- Date: Fri, 29 Jan 2010 10:56:05 +0100
- Organization: ProVal
Le Thu, 28 Jan 2010 16:49:01 +0100, Razvan Voicu <razvan AT comp.nus.edu.sg> a écrit:
Hi Cedric,
You are right. However, I think using 'fix' is a matter of preference after all. It is indeed unsound from a pure sequent-calculus point of view, but in Coq the 'Guarded' command comes to the rescue, telling the user if the type checker detects unguarded applications of the "unsound" hypothesis up to the current point in the proof (one major disadvantage is that you can't employ the automated tactics while the unsound hypothesis is present in the current sequent, you must clear it first).
I would actually appreciate a (yet another unsound) tactic that would allow me to create mutually recursive 'fix' constructs.
Here's another little gem using 'fix' :
Inductive even : nat -> Prop :=
e0 : even 0
| eS : forall n, even n -> even (S (S n)).
Goal forall n, even n \/ ~ even n.
fix circ 1.
intros [|[|n]].
left ; constructor.
right ; intro H ; inversion H.
assert (H := circ n) ; clear circ.
destruct H.
left ; constructor ; assumption.
right ; intro H1; apply H ; inversion H1 ; assumption.
Save.
Razvan
I wasn't aware of this feature, I may have use of it one day...
But, "Guarded" should be IMO used only for debugging proofs,
meaning that you have fallen into some error.
I think also that "prevent is better than fixing" and knowing
that you are in an unguarded situation will not tell you how
to go in a guarded situation.
Cédric AUGER
Univ Paris-Sud, Laboratoire LRI, UMR 8623, F-91405, Orsay
- [Coq-Club] inductive types and well-foundness of the structural orderings, Gyesik Lee
- Re: [Coq-Club] inductive types and well-foundness of the structural orderings, Jean-Francois Monin
Matthieu Sozeau
Razvan Voicu
Gyesik Lee
AUGER
Razvan Voicu
- Re: [Coq-Club] inductive types and well-foundness of the structural orderings, AUGER
Razvan Voicu
AUGER
Gyesik Lee
Razvan Voicu
