- To: Bas Spitters <spitters AT cs.ru.nl>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Unicode input
- Date: Wed, 17 Feb 2010 14:05:02 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:from:date :x-google-sender-auth:message-id:subject:to:cc:content-type; b=mz3ElB/5zQdezHU6PLJHAHj6se8tSjCu9gM0uyqfY/Bdx2Tsmx8MUrdxNqvcKFZTqO uSR6u1TlRFvky3Lt8oI/OnJKdUoBFWzDVn2RE7iEK6ctY/wCYzIQXBR8dqujM2lQfDWj Uljo1si3NcheYlV7CotxKbC6d4dXTY9Rz3cBY=
The method of agda is implemented via emacs input methods, it is also
possible to use this method in proofgeneral and any other emacs mode:
simply type:
M-x set-input-method <return> TeX <return>
for coqide the only method I know of is the one explained in the coq
reference manual:
http://coq.inria.fr/coq/refman/Reference-Manual019.html#toc106
Hope this helps,
Pierre Courtieu
2010/2/17 Bas Spitters
<spitters AT cs.ru.nl>:
> What method do people use to input unicode characters, preferably
> methods that work with coqide.
> The agda way seems nice:
> http://wiki.portal.chalmers.se/agda/agda.php?n=Docs.UnicodeInput
> Thanks,
> Bas
- [Coq-Club] Unicode input, Bas Spitters
- Re: [Coq-Club] Unicode input, Pierre Courtieu
Pierre-Marie Pédrot
Bas Spitters
- Re: [Coq-Club] Unicode input, Danko Ilik
Bas Spitters
- Re: [Coq-Club] Unicode input, Nils Anders Danielsson
Pierre-Marie Pédrot
- <Possible follow-ups>
- Fwd: [Coq-Club] Unicode input,
Danko Ilik
Pierre Courtieu
Bas Spitters
Pierre Letouzey
Benjamin Pierce
- Re: [Coq-Club] Unicode input, Frédéric Besson
Benjamin Pierce
Pierre Letouzey
Bas Spitters
Pierre Courtieu
