- From: Pierre Letouzey <Pierre.Letouzey AT pps.jussieu.fr>
- To: Bas Spitters <spitters AT cs.ru.nl>
- Cc: Pierre Courtieu <Pierre.Courtieu AT cnam.fr>, Danko Ilik <dankoilik AT gmail.com>, Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Unicode input
- Date: Tue, 23 Feb 2010 12:12:46 +0100
On Tue, Feb 23, 2010 at 12:03:42PM +0100, Bas Spitters wrote:
> This approach would clutter the name space.
> It would be better to change extraction mechanism.
> Best,
> Bas
Well, it would be better to change ocaml to allow unicode identifiers.
But since this is quite unlikely to happen anytime soon, I indeed plan
to do some name mangling at extraction time. Won't be pretty, but if
it helps...
Regards,
Pierre
> On Tue, Feb 23, 2010 at 10:53 AM, Pierre Courtieu
>Â <Pierre.Courtieu AT cnam.fr>
> wrote:
> > I suppose that using unicode only in notations is a way to work around
> > this limitation of ocaml.
> > Cheers,
> > Pierre Courtieu
> > 2010/2/22 Danko Ilik
>Â >Â <dankoilik AT gmail.com>:
> >> I forward the e-mail that was meant to go to coq-club:
> >>> From: Bas Spitters
>Â >>>Â <spitters AT cs.ru.nl>
> >>> Date: February 22, 2010 4:39:42 PM GMT+01:00
> >>> To: Danko Ilik
>Â >>>Â <dankoilik AT gmail.com>
> >>> It seems that haskell does support unicode, but there are some
> >>> problems with lambdas:
> >>> http://hackage.haskell.org/trac/ghc/ticket/1102
> >>> Pierre: Does switching to unicode mean that we will have to give up
> >>> extraction??
> >>> Best,
> >>> Bas
> >> Danko Iliḱ
- [Coq-Club] Unicode input, Bas Spitters
- Re: [Coq-Club] Unicode input,
Pierre Courtieu
Pierre-Marie Pédrot
Bas Spitters
- Re: [Coq-Club] Unicode input, Danko Ilik
Bas Spitters
- Re: [Coq-Club] Unicode input, Nils Anders Danielsson
Pierre-Marie Pédrot
- <Possible follow-ups>
- Fwd: [Coq-Club] Unicode input,
Danko Ilik
Pierre Courtieu
Bas Spitters
- Re: [Coq-Club] Unicode input, Pierre Letouzey
Benjamin Pierce
- Re: [Coq-Club] Unicode input, Frédéric Besson
Benjamin Pierce
Bas Spitters
Pierre Courtieu
- Re: [Coq-Club] Unicode input, vincent . gross
Pierre Courtieu
