- To: Pierre Letouzey <Pierre.Letouzey AT pps.jussieu.fr>
- Cc: Bas Spitters <spitters AT cs.ru.nl>, Pierre Courtieu <Pierre.Courtieu AT cnam.fr>, Danko Ilik <dankoilik AT gmail.com>, Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Unicode input
- Date: Tue, 23 Feb 2010 09:36:37 -0500
Since we're talking about unicode, may I ask if people are successfully using unicode notations with proof general and emacs 22.0? For me, the notations display correctly in the .v buffer, but display as ? in the goals and responses buffers.
(I see that newer PG releases use a different mechanism for displaying unicode, but this requires upgrading to emacs 23, which is not installed everywhere yet and indeed doesn't completely work on my machine yet, for reasons yet to be diagnosed...)
- Benjamin
On Feb 23, 2010, at 6:12 AM, Pierre Letouzey wrote:
On Tue, Feb 23, 2010 at 12:03:42PM +0100, Bas Spitters wrote:
This approach would clutter the name space.
It would be better to change extraction mechanism.
Best,
Bas
Well, it would be better to change ocaml to allow unicode identifiers.
But since this is quite unlikely to happen anytime soon, I indeed plan
to do some name mangling at extraction time. Won't be pretty, but if
it helps...
Regards,
Pierre
On Tue, Feb 23, 2010 at 10:53 AM, Pierre Courtieu
wrote:
I suppose that using unicode only in notations is a way to work around
this limitation of ocaml.
Cheers,
Pierre Courtieu
2010/2/22 Danko Ilik
<dankoilik AT gmail.com>:
I forward the e-mail that was meant to go to coq-club:
Date: February 22, 2010 4:39:42 PM GMT+01:00
To: Danko Ilik
It seems that haskell does support unicode, but there are some
problems with lambdas:
http://hackage.haskell.org/trac/ghc/ticket/1102
Pierre: Does switching to unicode mean that we will have to give up extraction??
Best,
Bas
Danko Iliḱ
- [Coq-Club] Unicode input, Bas Spitters
- Re: [Coq-Club] Unicode input,
Pierre Courtieu
Pierre-Marie Pédrot
Bas Spitters
- Re: [Coq-Club] Unicode input, Danko Ilik
Bas Spitters
- Re: [Coq-Club] Unicode input, Nils Anders Danielsson
Pierre-Marie Pédrot
- <Possible follow-ups>
- Fwd: [Coq-Club] Unicode input,
Danko Ilik
Pierre Courtieu
Bas Spitters
Pierre Letouzey
- Re: [Coq-Club] Unicode input, Benjamin Pierce
- Re: [Coq-Club] Unicode input, Frédéric Besson
Pierre Letouzey
Bas Spitters
Pierre Courtieu
- Re: [Coq-Club] Unicode input, vincent . gross
Pierre Courtieu
