- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Unicode input
- Date: Tue, 23 Feb 2010 17:28:05 +0100
I wrote and somehow packaged a uim module for CoqIDE. It's available in svn
trunk and v8.3.
1) install uim on your system
2) from coq sourcedir, issue a ./configure. If your uim installation is in a
non standard place, use the -uim-script-path option
3) issue a make install-im as root
4) using uim-pref-gtk, select CoqIDE to be the default IM
If you want CoqIDE to use uim by default, set the environment variable
GTK_IM_MODULE to "uim"
This module uses the same escape sequences as the emacs TeX mode
- Re: [Coq-Club] Unicode input, (continued)
Pierre-Marie Pédrot
Bas Spitters
- Re: [Coq-Club] Unicode input, Danko Ilik
Bas Spitters
- Re: [Coq-Club] Unicode input, Nils Anders Danielsson
- Fwd: [Coq-Club] Unicode input,
Danko Ilik
Pierre Courtieu
Bas Spitters
Pierre Letouzey
Benjamin Pierce
- Re: [Coq-Club] Unicode input, Frédéric Besson
Benjamin Pierce
Pierre Letouzey
Bas Spitters
Pierre Courtieu
- Re: [Coq-Club] Unicode input, vincent . gross
Pierre-Marie Pédrot
