coq-club - Re: [Coq-Club] local definitions/proof environments
chronological Thread
  • To: "Matthieu Sozeau" <mattam AT mattam.org>, "Vladimir Voevodsky" <vladimir AT ias.edu>
  • Cc: "Coq Club" <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] local definitions/proof environments
  • Date: Tue, 02 Mar 2010 18:12:35 +0100
  • Organization: ProVal
Le Tue, 02 Mar 2010 18:05:17 +0100, Matthieu Sozeau <mattam AT mattam.org> a écrit:
Le 2 mars 10 Ã  09:59, Vladimir Voevodsky a Ã©crit :
Suppose I have some local definitions in a section which are introduced with [Let]. Then they start showing up in the local environments of all the proofs in the section. How can I ask Coq not to display some of these definitions on the "goals" pages of the proofs?
Dear Vladimir,
   you can use either [Definition]s or [Notation]s instead of [Let]
to define abbreviations that won't appear in the proof context.
Hope this helps,
-- Matthieu
"Notation" is probably best than "Definition", as it will die after the "End [Section].";
but if your local definition is big and used many times in each definition,
proof terms will be unnecessary huge.
Cédric AUGER
Univ Paris-Sud, Laboratoire LRI, UMR 8623, F-91405, Orsay
