- To: Mathieu Boespflug <mboes AT tweag.net>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Programming language shootout for Coq?
- Date: Wed, 3 Mar 2010 12:41:39 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:from:date :x-google-sender-auth:message-id:subject:to:cc:content-type; b=jMP4/uH1quruIc0ueYav/YFN95qdvZhXTQgn/3upia0d0FoCK7t0v5DtZZPGtCFGaw cBONp8q4nA4i8CaPAI55q4/h9B3eCi1agbSNS2NfifTceijvPNSlzaxZLq5EcSaG4amc 7R0D/Tk5q39ybhhSxqd4OIic2Ir3Ow/RVM05o=
Very interesting.
I guess you are referring to your paper:
http://www.lix.polytechnique.fr/~mboes/papers/padl10.pdf
Could you explain more about the status of your implementation for Coq?
I would be keen to try it on our real number computations:
Certified Exact Transcendental Real Number Computation in Coq (Russell
O'Connor)
http://arxiv.org/abs/0805.2438
A computer verified, monadic, functional implementation of the
integral (Russell O'Connor, Bas Spitters)
http://arxiv.org/abs/0809.1552
In the latter paper we experimented with threaded execution of the
extracted program.
We did this manually, but easily, for OCaml, giving a 3 times speed
up on a four processor machine.
We tried to do it semi-automatically in haskell.
I.e. we defined
par :: a -> b -> b
pseq :: a -> b -> b
by trivial projections in Coq and then a small modification of the
extracted code would do.
Unfortunately, Coq's modules do not extract to haskell.
Finally, I understand that Isabelle allows threaded execution.
# ML: support for Poly/ML 5.3.0, with improved reporting of compiler
errors and run-time exceptions, including detailed source positions.
# Parallel checking of nested Isar proofs, with improved scalability
up to 8 cores.
http://www.cl.cam.ac.uk/research/hvg/Isabelle/
Would your approach allow something similar?
Best,
Bas
On Tue, Mar 2, 2010 at 10:13 PM, Mathieu Boespflug
wrote:
> Hi,
>> There is anecdotal evidence that Coq looses a factor between 5-50 in
>> speed to the extracted OCaml program.
>> It would be nice if we could substantiate this.
> In my experience, if using the Coq VM (vm_compute tactic), performance
> loss compared to state of the art compilers for functional languages
> is limited to a factor of 5-10, which is a typical performance gap
> between bytecode interpreters and compilation to native code. There is
> current work nearing completion, however, on adding a new execution
> mechanism to Coq where Coq terms are compiled to native code. This
> execution mechanism uses the stock OCaml compiler as a backend to
> generate native code so execution should be about as fast as any
> regular OCaml program.
> -- Mathieu
- Re: [Coq-Club] Programming language shootout for Coq?, (continued)
Stéphane Glondu
- Re: [Coq-Club] Programming language shootout for Coq?, Danko Ilik
Bas Spitters
Adam Koprowski
Greg Morrisett
- Re: [Coq-Club] Programming language shootout for Coq?, Adam Koprowski
Greg Morrisett
Adam Koprowski
- [Coq-Club] local definitions/proof environments, Vladimir Voevodsky
Mathieu Boespflug
- Re: [Coq-Club] Programming language shootout for Coq?, Bas Spitters
Mathieu Boespflug
Bas Spitters
- Re: [Coq-Club] Programming language shootout for Coq?, Mathieu Boespflug
Bas Spitters
Mathieu Boespflug
Stéphane Glondu
