- To: Mathieu Boespflug <mboes AT tweag.net>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Programming language shootout for Coq?
- Date: Thu, 4 Mar 2010 16:42:58 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:from:date :x-google-sender-auth:message-id:subject:to:cc:content-type; b=MCPYwIMgs2SxONmNCn7GwdQEVmYJUTEJFgqQYGKMFvxAHPvHggHAcbOXRg/lw6l4CZ 5Q6V++TeYVFNScfsNR7aTALO2TGoLD7WP5zws4MzfaX5+6iFKZ3s+6Atz1W8xtgPItIZ vQLGkZt4YK65rH9lqfcHeP6rrKO/n+0PIW66k=
On Thu, Mar 4, 2010 at 3:22 PM, Mathieu Boespflug
wrote:
> By the end
> of the week we should have a significantly more user-friendly version
> for you to try.
Great!
>> I would be keen to try it on our real number computations:
>> Certified Exact Transcendental Real Number Computation in Coq (Russell
>> O'Connor)
>> http://arxiv.org/abs/0805.2438
>> A computer verified, monadic, functional implementation of the
>> integral (Russell O'Connor, Bas Spitters)
>> http://arxiv.org/abs/0809.1552
> Great! We are always looking for new benchmarks.
We have a list of benchmarks in:
CoRN/examples
most of them are just reductions of closed terms, no variables.
For example:
(* approximate e^pi - pi. May take a minute *)
Time Eval vm_compute in answer 20 (exp (compress CRpi) - CRpi)%CR.
> I'm not sure what kind of parralelism you are seeking. Do you mean
> checking independent parts of a proof in parralel or would like for an
> expensive conversion test to be run on multiple cores at once? We have
> not thought about parralelism yet, but I don't think our approach
> poses any particular problems in that regard. It's conceivable that
> specific Coq-level axioms be mapped to OCaml primitives for multicore
> computation, as is possible during extraction.
During integration we need to sample a real valued function on many points.
This can be done in parallel.
Are you saying that the current Coq-extraction supports multicores by default?
Best,
Bas
- Re: [Coq-Club] Programming language shootout for Coq?, (continued)
Bas Spitters
Adam Koprowski
Greg Morrisett
- Re: [Coq-Club] Programming language shootout for Coq?, Adam Koprowski
Greg Morrisett
Adam Koprowski
- [Coq-Club] local definitions/proof environments, Vladimir Voevodsky
Mathieu Boespflug
Bas Spitters
Mathieu Boespflug
- Re: [Coq-Club] Programming language shootout for Coq?, Bas Spitters
- Re: [Coq-Club] Programming language shootout for Coq?, Mathieu Boespflug
Mathieu Boespflug
Bas Spitters
Bas Spitters
