- To: coq-club AT inria.fr
- Subject: [Coq-Club] more generous context when typing branches of [match]?
- Date: Wed, 24 Mar 2010 05:09:18 +0000
- Cancel-lock: sha1:FO7GSKcjhY6alX+5n3Xwz3fisI8=
- Organization: Myself
It seems that in Coq's rule for typing [match], the hypotheses for the
well-typedness of the branches have a more restrictive context than I'd
like (perhaps for a good reason!).
Here's an example of what I mean:
Require Import ZArith.
Require Import Coq.Init.Datatypes.
Open Scope Z_scope.
Require Import Coq.Init.Specif.
Inductive test : Z -> Set :=
| up : forall z, test (z+1) -> test z
| down : forall z, test z -> test (z+1).
Definition next(z:Z)(t:test z) : sum (test (z+1)) (test (z-1)) :=
match t with
| down _ d => inr (test (z-1)) d
| up _ u => inl (test (z+1)) u
end.
This example is greatly simplified from the actual case I'm working on,
so I apologize if I've accidentally made the solution trivial in the
process. When typing the body of the second branch (everything between
the last [=>] and [end.]), we introduce a fresh variable [z0] and the
assumption [u:(test z0)]. But shouldn't it be safe for the typing
context to also include some sort of assumption along the lines of
[t:(test (z0+1))] or [(test z)=(test (z0+1))]?
It seems that Coq's typing rules do not include a provision for this --
am I mistaken? Each branch of [match] gets typed as if it were a
function whose arguments are the constructor's arguments, but the context
is unchanged. To put it less formally, it seems like when a constructor
definition for type [test] ends with
| ... -> test XYZ
then the corresponding branch of a [match] ought to be granted the
assumption that the type of the value being [match]ed upon is equal to
[test XYZ].
My current workaround is to (1) add a recursively uniform parameter and
(2) stash a proof relating the uniform parameter to a nonuniform
parameter in each constructor:
Inductive test (z:Z) : Z -> Set := ..
| up : forall z0, z0=z -> test (z0+1) -> test z
| down : forall z0, z0+1=z -> test z0 -> test z
but the added verbosity is getting to be a problem. Are there any other
solutions?
Thanks!
- a
- [Coq-Club] more generous context when typing branches of [match]?, Adam Megacz
- Re: [Coq-Club] more generous context when typing branches of [match]?, Damien Pous
- Re: [Coq-Club] more generous context when typing branches of [match]?, Adam Chlipala
Matthew Brecknell
- [Coq-Club] Re: more generous context when typing branches of [match]?, Adam Megacz
