- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] more generous context when typing branches of [match]?
- Date: Wed, 24 Mar 2010 07:49:45 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:content-type :content-transfer-encoding; b=q1HqjAm5Cy9DnnS5wiy+jovQSdGGjFK/7UdduyZ10t63e2jT4kRbWavbMG9doGO4Au /hwSdAuLP7tWNzGkSo8ibNdT7yOoAgr6uPl9BSTgyEwFJb9fk0yGbwmjHogqwBpOoDgV awREnIFOmzC5xO8gJjHb3ciF+1pn9vrZoDSns=
Maybe you could replace the inductive type with the following one?
Inductive test : Z -> Set :=
| up : forall z, test (z+1) -> test z
| down : forall z, test (z-1) -> test z.
Definition next(z:Z)(t:test z) : sum (test (z+1)) (test (z-1)) :=
match t with
| down _ d => inr _ d
| up _ u => inl _ u
end.
Damien
2010/3/24 Adam Megacz
<megacz AT cs.berkeley.edu>:
> It seems that in Coq's rule for typing [match], the hypotheses for the
> well-typedness of the branches have a more restrictive context than I'd
> like (perhaps for a good reason!).
> Here's an example of what I mean:
> Require Import ZArith.
> Require Import Coq.Init.Datatypes.
> Open Scope Z_scope.
> Require Import Coq.Init.Specif.
> | down : forall z, test z -> test (z+1).
> match t with
> | down _ d => inr (test (z-1)) d
> | up _ u => inl (test (z+1)) u
> end.
> This example is greatly simplified from the actual case I'm working on,
> so I apologize if I've accidentally made the solution trivial in the
> process. When typing the body of the second branch (everything between
> the last [=>] and [end.]), we introduce a fresh variable [z0] and the
> assumption [u:(test z0)]. But shouldn't it be safe for the typing
> context to also include some sort of assumption along the lines of
> [t:(test (z0+1))] or [(test z)=(test (z0+1))]?
> It seems that Coq's typing rules do not include a provision for this --
> am I mistaken? Each branch of [match] gets typed as if it were a
> function whose arguments are the constructor's arguments, but the context
> is unchanged. To put it less formally, it seems like when a constructor
> definition for type [test] ends with
> | ... -> test XYZ
> then the corresponding branch of a [match] ought to be granted the
> assumption that the type of the value being [match]ed upon is equal to
> [test XYZ].
> My current workaround is to (1) add a recursively uniform parameter and
> (2) stash a proof relating the uniform parameter to a nonuniform
> parameter in each constructor:
> Inductive test (z:Z) : Z -> Set := ..
> | up : forall z0, z0=z -> test (z0+1) -> test z
> | down : forall z0, z0+1=z -> test z0 -> test z
> but the added verbosity is getting to be a problem. Are there any other
> solutions?
> Thanks!
> - a
- [Coq-Club] more generous context when typing branches of [match]?, Adam Megacz
- Re: [Coq-Club] more generous context when typing branches of [match]?, Damien Pous
- Re: [Coq-Club] more generous context when typing branches of [match]?, Adam Chlipala
Matthew Brecknell
- [Coq-Club] Re: more generous context when typing branches of [match]?, Adam Megacz
