- To: Adam Megacz <megacz AT cs.berkeley.edu>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Re: more generous context when typing branches of [match]?
- Date: Thu, 25 Mar 2010 08:24:56 -0400
Adam Megacz wrote:
If you try the [refl_equal] trick, the typechecker -- which checks
expressions in a more-or-less bottom-up traversal of the syntax tree --
will fail before it gets up to the level where the equality hypothesis
becomes available:
Definition next (z: Z) (t: test z) (q:test (z+1)) : Z.
refine (fix next (z:Z) (t:test z) (q:test (z+1)) :=
match t in test z0
return z = z0 -> Z with
| down _ d => fun Heq => next z t d
| up _ u => fun Heq => 3
end (refl_equal z)).
I really think this is the point where it makes sense for you to read something that introduces the key techniques of dependently-typed programming in Coq. Matthew didn't say that [refine] would use [Heq] automatically to perform type-casts. For that, you would need something like Program.
I think your function definition has a typo, where the last two recursive arguments to [next] are reversed. Switching that, it's easy to arrive at an accepted program using the technique Matthew suggested. (I'm starting from your structurally recursive version, not the above code.)
Fixpoint next(n:nat)(z:Z)(t:test z)(q:test (z+1)) : Z :=
match n with
| 0%nat => 3
| (S n') =>
match t in test z0 return z = z0 -> Z with
| down _ d => fun Heq : z = _ + 1 =>
next n' _ d (match Heq in _ = Z return test Z with
| refl_equal => t
end)
| up _ u => fun _ => 3
end (refl_equal _)
end.
- [Coq-Club] more generous context when typing branches of [match]?, Adam Megacz
- Re: [Coq-Club] more generous context when typing branches of [match]?, Damien Pous
- Re: [Coq-Club] more generous context when typing branches of [match]?, Adam Chlipala
Matthew Brecknell
- [Coq-Club] Re: more generous context when typing branches of [match]?,
Adam Megacz
- Re: [Coq-Club] Re: more generous context when typing branches of [match]?, Adam Chlipala
Adam Megacz
