- To: coq-club AT inria.fr
- Cc: bruno AT ropas.snu.ac.kr
- Subject: [Coq-Club] Indexed Types Pattern Matching Problem
- Date: Wed, 17 Mar 2010 14:34:11 +0900 (KST)
Hello,
I have been trying to use Coq to do some programming with indexed types,
but I found that there are some issues with pattern matching. I am hoping
that you could provide some help. I tried to create a minimal version of
the code that illustrates the issues:
Inductive Rep : Type :=
| Plus : Rep -> Rep -> Rep
| Rec : Rep
| Const : Type -> Rep.
Inductive Interpret (r : Rep) : Rep -> Type :=
| inl : forall a b, Interpret r a -> Interpret r (Plus a b)
| inr : forall a b, Interpret r b -> Interpret r (Plus a b)
| rec : Interpret r r -> Interpret r Rec
| const : forall a, a -> Interpret r (Const a).
Inductive T :=
| A : nat -> T
| B : T -> T.
Definition RT := Plus (Const nat) Rec.
My goal is to define a function:
Fixpoint to_T (x : Interpret RT RT) : T := ...
which converts between a structure "Interpret RT RT" and T. I tried many
things, none of which worked. Let me tell you about these:
1) A first attempt is:
match x with
| inl a b (const _ n) => A n
| inr a b r => B (to_T r)
| _ => A 0 (** not needed **)
end.
However this fails.
2) I then tried to generalize a bit:
Fixpoint to_T (a : Rep) (x : Interpret RT a) : T :=
match x with
| inl a b (const _ n) => A n (* fails here, does not refine the type *)
| _ => A 0
end.
This version fails because coq apparently fails to refine the type of
the value |n| to a natural number. Thus I cannot apply the constructor A.
3) Using the proof mode I can get the first case to work:
Definition to_T (a : Rep) (x : Interpret RT a) : (a = RT) -> T.
intros a x.
refine (
match x with
| inl a b (const _ n) => _
| _ => fun p => A 0
end
). intros. inversion H. subst a0.inversion i.exact (A X).
Defined.
But this is not the function I want.
4) Finally:
refine (fix to_T (a : Rep) (x : Interpret RT a) : (a = RT) -> T :=
match x with
| inl a b _ => _
| inr a b _ => _
| rec _ => _
| const a _ => _
end
); intros; try discriminate.
inversion H. subst a0. inversion i. exact (A X).
inversion H. subst b. inversion i. exact (to_T RT X (refl_equal RT)).
Defined.
In this definition evrything seems to work, but the termination checker
does not like it.
I am running out of ideas now. Any suggestions?
Thanks in advance for any help or suggestions.
Bruno Oliveira
- [Coq-Club] Indexed Types Pattern Matching Problem, Bruno Oliveira
- <Possible follow-ups>
Gyesik Lee
- Re: [Coq-Club] Indexed Types Pattern Matching Problem,
Roman Beslik
Gyesik Lee
Roman Beslik
Gyesik Lee
Roman Beslik
- Message not available
- Re: [Coq-Club] Indexed Types Pattern Matching Problem, Roman Beslik
- Re: [Coq-Club] Indexed Types Pattern Matching Problem, Gyesik Lee
Roman Beslik
Gyesik Lee
Roman Beslik
Gyesik Lee
Roman Beslik
- Re: [Coq-Club] Indexed Types Pattern Matching Problem, Adam Chlipala
