coq-club - [Coq-Club] calculating values depending on the structure of proofs
chronological Thread
  • To: coq-club <coq-club AT inria.fr>
  • Subject: [Coq-Club] calculating values depending on the structure of proofs
  • Date: Thu, 8 Apr 2010 03:46:32 +0900
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:date:x-google-sender-auth:message-id:subject :from:to:content-type; b=kkCwmEQe0pLr2dAvWkSNQuFck7VDyJwXwsE2E8moUGB3B0GfgHpV+GxVKygicTFFiM s5Ar96u2QDJJehMF7DMZ0zKqNg0caoJLLu3kboEl25iikidvzwLlmnyC1sEdTFZTMvoB 2gHGUA/dP70ct+RvtyNa1B0ZQcfAR+BUctflk=
Dear all,
I am a PhD student studying formal methods in Korea university.  (I think
I have not introduced myself properly yet.)  I have two elementary
questions about proof-irrelevance or something.
Sometimes I want to define functions which calculate values (in sort Set)
depending not on the mere existence but on the concrete structure of some
proofs (in sort Prop).  As a simplified example, let me try to define a
function which converts each proof of 'ex P' into a corresponding
certified value:
    Coq < Definition foo {P} : (exists x, P x) -> { n:nat | P n }.
    foo < intros P H.
    1 subgoal
      P : nat -> Prop
      H : exists x : nat, P x
       {n : nat | P n}
Though H already contains all the information needed (a natural number
together with a proof that that number satisfies P), I cannot extract
those information in this situation.  Any attempt such as 'destruct H',
'case H' or 'elim H' fails.  Even the definition of my own 'ex_rec' (for
eliminatig H) is also rejected:
    Definition my_ex_rec {A:Type} {P:A->Prop} {S:Set}
                         (f : forall x, P x -> S) (e:ex P) : S :=
      match e with
      | ex_intro x H => f x H
      end.
QUESTION 1: Is there really no way to retrieve detailed information from
the proofs of inductive predicates (whose final type is Prop) when the
current goal has sort Set?
By using eexists, (I thought) I detoured to a subgoal having sort Prop.
Now, even H can be destructed without any complaint:
    foo < eexists.
    1 subgoal
      P : nat -> Prop
       P ?6
    foo < destruct H as [x H].
    1 subgoal
      P : nat -> Prop
      x : nat
      H : P x
       P ?7
QUESTION 2: Why 'eexact H' fails here?
    foo < eexact H.
    Toplevel input, characters 0-8:
    > eexact H.
    Error: Impossible to unify "?7" with "x".
Thanks in advance.  :^)
CHA Reeseo
http://www.reeseo.net/
