- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] calculating values depending on the structure of proofs
- Date: Wed, 7 Apr 2010 18:20:08 -0400
Le 7 avr. 2010 à 18:08, Adam Koprowski a écrit :
> I have a new (but related) question:
> P : nat -> Prop
> H : {x : nat | P x}
> {y : nat | P y}
> This example is too simple and can be proved by "assumption", but let's
> forget about it. Here,
> * "destruct H; eexists; eassumption" succeeds, but
> * "eexists; destruct H; eassumption" fails
> because of the reason above. But visually, the results of
> * "destruct H; eexists" and
> * "eexists; destruct H"
> look the same, and it's somewhat confusing:
> P : nat -> Prop
> x : nat
> p : P x
> P ?6
> Does Coq have any command or configuration option to enable some kind of
> 'visual indication' on the context?
> I believe that 'Show Existentials' is what you are looking for:
> http://coq.inria.fr/refman/Reference-Manual010.html#@command192.
> Adam
The command [Set Printing Existential Instances] might be useful too,
it prints the substitution applied to the existential.
In that case, [destruct H; eexists] gives
P : nat -> Prop
x : nat
p : P x
P ?15 (* [P, x, p] *)
while [eexists; destruct H] gives:
P : nat -> Prop
x : nat
p : P x
P ?16 (* [P, exist (fun x0 : nat => P x0) x p] *)
-- Matthieu
- [Coq-Club] calculating values depending on the structure of proofs, CHA Reeseo
- [Coq-Club] Re: calculating values depending on the structure of proofs, CHA Reeseo
- Re: [Coq-Club] calculating values depending on the structure of proofs,
Adam Chlipala
CHA Reeseo
- Re: [Coq-Club] calculating values depending on the structure of proofs, Adam Chlipala
Adam Koprowski
- Re: [Coq-Club] calculating values depending on the structure of proofs, Matthieu Sozeau
CHA Reeseo
- Re: [Coq-Club] calculating values depending on the structure of proofs, Jean-Francois Monin
