coq-club - Re: [Coq-Club] calculating values depending on the structure of proofs
chronological Thread
  • To: CHA Reeseo <reeseo AT formal.korea.ac.kr>
  • Cc: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] calculating values depending on the structure of proofs
  • Date: Wed, 07 Apr 2010 18:08:28 -0400
CHA Reeseo wrote:
I have a new (but related) question:
       P : nat ->  Prop
       H : {x : nat | P x}
        {y : nat | P y}
This example is too simple and can be proved by "assumption", but let's
forget about it.  Here,
  * "destruct H; eexists; eassumption" succeeds, but
  * "eexists; destruct H; eassumption" fails
because of the reason above.  But visually, the results of
  * "destruct H; eexists" and
  * "eexists; destruct H"
look the same, and it's somewhat confusing:
       P : nat ->  Prop
       x : nat
       p : P x
        P ?6
Does Coq have any command or configuration option to enable some kind of
'visual indication' on the context?  For example, the following is just a
naive mock-up:
       P : nat ->  Prop
       (?6 : nat)
       x : nat
       p : P x
        P ?6
That's an interesting idea. The command [Show Existentials] will print the contexts of all remaining existential variables, which at least conveys all the same information, though in a more verbose form.
