coq-club - [Coq-Club] Re: Notation which uses parameters of a Record/Class?
chronological Thread
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] Re: Notation which uses parameters of a Record/Class?
  • Date: Thu, 15 Apr 2010 03:45:17 +0000
  • Cancel-lock: sha1:tkQRwW7BFOpQQzxnAmtu/PNgncA=
  • Organization: Myself
AUGER Cédric
<Cedric.Auger AT lri.fr>
 writes:
>   Reserved Notation "a ** b" (at level 50).
> Section Monoid.
>   Variable Carrier: Set.
>   Variable mult_monoid: Carrier -> Carrier -> Carrier.
>   Notation "a ** b" := (mult_monoid a b).
>   Class Monoid :=
>   { neutral : Carrier
Yes, this is what I was previously doing; unfortunately [Section]s are
incompatible with [Module]s, which I would like to start using.
Bas Spitters
<spitters AT cs.ru.nl>
 writes:
> Class SemiGroupOp A := sg_op: A â†’ A â†’ A.
> Infix "&" := sg_op (at level 50, left associativity).
>   Class Group {op: SemiGroupOp A} ...
>     ; ginv_l: `(- x & x = mon_unit)
Ah, this is quite a nice trick!  It seems to work for my script.  Thank
you very much!
> Context A {e: Equiv A}.
By the way, how is the [Context] command different from [Variable]?  I
can't find [Context] in the manual:
  http://www.lix.polytechnique.fr/coq/refman/command-index.html
but my version of Coq certainly accepts it, and I see it appears once in
the Sozeau+Oury paper.  Is it just another synonym for [Variable]?
  - a
