- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Re: Notation which uses parameters of a Record/Class?
- Date: Thu, 15 Apr 2010 12:56:31 +0200
Le Thu, 15 Apr 2010 03:45:17 +0000,
Adam Megacz
<megacz AT cs.berkeley.edu>
a écrit :
> AUGER Cédric
>Â <Cedric.Auger AT lri.fr>
> writes:
> > Reserved Notation "a ** b" (at level 50).
> > Section Monoid.
> > Variable Carrier: Set.
> > Variable mult_monoid: Carrier -> Carrier -> Carrier.
> > Notation "a ** b" := (mult_monoid a b).
> > Class Monoid :=
> > { neutral : Carrier
> Yes, this is what I was previously doing; unfortunately [Section]s are
> incompatible with [Module]s, which I would like to start using.
What do you mean with that? You can perfectly open a section inside a
module (I am almost certain that you also can open a module inside a
section, but that is not the problem here).
About modules, I expect you to have good reason to use them, as in Coq,
they are a lot less interesting as one can think at first glance.
Records, Type Classes, and Inductives, are almost as powerfull (and
are even often more powerfull) as Modules.
http://coq.inria.fr/cocorico/RecordsNotModules
That post was a little too excessive, I tried to moderate it with
http://coq.inria.fr/cocorico/ModulesNotRecords
what I wrote in the latter may be not correct nor complete, but I tried
to write down my little experience on it (I didn't write the previous).
> Bas Spitters
>Â <spitters AT cs.ru.nl>
> writes:
> > Class SemiGroupOp A := sg_op: A → A → A.
> > Infix "&" := sg_op (at level 50, left associativity).
> > Class Group {op: SemiGroupOp A} ...
> > ; ginv_l: `(- x & x = mon_unit)
> Ah, this is quite a nice trick! It seems to work for my script.
> Thank you very much!
> > Context A {e: Equiv A}.
> By the way, how is the [Context] command different from [Variable]? I
> can't find [Context] in the manual:
> http://www.lix.polytechnique.fr/coq/refman/command-index.html
> but my version of Coq certainly accepts it, and I see it appears once
> in the Sozeau+Oury paper. Is it just another synonym for [Variable]?
> - a
- [Coq-Club] Notation which uses parameters of a Record/Class?, Adam Megacz
- Re: [Coq-Club] Notation which uses parameters of a Record/Class?, Bas Spitters
- Re: [Coq-Club] Notation which uses parameters of a Record/Class?, AUGER Cédric
- Message not available
- [Coq-Club] Re: Notation which uses parameters of a Record/Class?,
Adam Megacz
- Re: [Coq-Club] Re: Notation which uses parameters of a Record/Class?, Bas Spitters
- Re: [Coq-Club] Re: Notation which uses parameters of a Record/Class?, AUGER Cédric
Adam Megacz
