coq-club - [Coq-Club] Notation which uses parameters of a Record/Class?
chronological Thread
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] Notation which uses parameters of a Record/Class?
  • Date: Wed, 14 Apr 2010 04:06:45 +0000
  • Cancel-lock: sha1:fcEF6xI6INwhGWmskLDIkrUhs0s=
  • Organization: Myself
Is there any way to have a [Notation] whose definition involves
parameters of the Record/Class currently being defined?
Example:
  Class Monoid (Carrier:Set)(mult:Carrier->Carrier->Carrier) :=
  { neutral : Carrier
  ; identL  : forall a,     (mult a neutral) = a
  ; identR  : forall a,     (mult neutral a) = a
  ; assoc   : forall a b c, (mult a (mult b c)) = (mult (mult a b) c)
I would much rather write this (especially for classes which are more
complicated than a simple Monoid), but Coq won't accept it:
  Reserved Notation "a ** b" (at level 50).
  { neutral : Carrier
  ; identL  : forall a,     a**neutral = a
  ; identR  : forall a,     neutral**a = a
  ; assoc   : forall a b c, a**(b**c) = (a**b)**c
  } where "a ** b" := (mult a b).
I tried putting the 'where "a ** b" := (mult a b)' in a few other places
to no avail.  Unfortunately due to other constraints I can't just add a
new field and a notation for it, like this:
  { mult_again := mult where "a ** b" := (mult_again a b)
By the way, the definition above is technically illegal according to the
Coq manual (you're not supposed to be able to put "where" after a ":="
clause according to a strict reading of the BNF) but Coq 8.2pl3 accepts
it anyways.  Not sure if the BNF should be more permissive or Coq should
be stricter.
Thanks,
  - a
