coq-club - Re: [Coq-Club] record field is "lost" if import is used
chronological Thread
  • To: Patrice Chalin <chalin AT encs.concordia.ca>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] record field is "lost" if import is used
  • Date: Wed, 12 May 2010 21:05:11 +0200
Hi,
> Consider the following simple record definition (contained in, say,
> RecTest.v
> with nothing else):
> Record R : Type := {
>  f1 : nat;
>  f2 : nat
> This is accepted by Coq, but if I add
>   Require Import Imp.
> to the start of the file where Imp is the theory from B.Pierce et al.'s
> Software Foundations
> (http://www.cs.princeton.edu/courses/archive/fall09/cos441/sf/) then I get
> the
> following error message:
>   Error: The reference f2 was not found in the current environment.
> Now I understand that f2 is effectively a "global" function and that there
> can
> be name clashes, but the error message is complaining that "f2" is _not
> found_.
>  In any case it doesn't matter what I name the second record component, I
> always get the same error. How can it be that an import can cause such an
> error
> to arise?
The culprit is the following notation to be found in file Imp.v:
  Notation "c1 ; c2" := (CSeq c1 c2) (at level 80, right associativity).
This conflicts with the notation for records so that
  Record R : Type := { f1 : nat; f2 : nat }.
is understood as
  Record R : Type := { f1 : ((nat; f2) : nat) }.
Try for instance,
  Parameter c:com -> Type.
  Coercion c:com >-> Sortclass.
  Parameter f2:com.
  Record R : Type := { f1:CSkip; f2:com }.
and it will define R with one field f1.
This is a serious drawback of the grammar extensibility. Nothing in
Coq prevents users to introduce conflicting grammar rules and
extensions have to be used with care. I agree that this one (about
";") is a particularly annoying one but I don't see a solution to work
around it.
Hugo Herbelin
