coq-club - Re: [Coq-Club] yet another pb with Notation (from Init/Logic.v)
chronological Thread
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] yet another pb with Notation (from Init/Logic.v)
  • Date: Fri, 14 May 2010 08:29:39 -0700
On May 14, 2010, at 3:27 AM, Hugo Herbelin wrote:
> Hi Jean-François,
> On Fri, May 14, 2010 at 08:31:54AM +0800, Jean-Francois Monin wrote:
>> [Previously: Re: [Coq-Club] record field is "lost" if import is used]
>> I have another problem with Imp.v, which is also related to
>> "Notation". The following inductive predicate should
>> be entirely defined using programming language notation,
>> but Coq is unable to parse "IF b1 THEN c1 ELSE c2" here.
>> Printing is OK. The conflict is with IF... then... else
>> from Init/Logic.v which seems to prevent a different use of IF.
I believe your notation is incorrect. It should be
Notation "'IFB' e1 'THEN' e2 'ELSE' e3 'FI'" :=
  (CIf e1 e2 e3) (at level 80, right associativity).
The example you provided uses [IF b1 THEN c1 ELSE c2], but it should be the
notation above or [IFB b1 THEN c1 ELSE c2]. If you are still having conflicts
double check the imports for that chapter.
--Dan
