- To: Hugo Herbelin <Hugo.Herbelin AT inria.fr>
- Cc: Jean-Francois Monin <jean-francois.monin AT imag.fr>, coq-club AT inria.fr
- Subject: Re: [Coq-Club] yet another pb with Notation (from Init/Logic.v)
- Date: Fri, 14 May 2010 13:17:22 -0400
>> I have another problem with Imp.v, which is also related to
>> "Notation". The following inductive predicate should
>> be entirely defined using programming language notation,
>> but Coq is unable to parse "IF b1 THEN c1 ELSE c2" here.
>> Printing is OK. The conflict is with IF... then... else
>> from Init/Logic.v which seems to prevent a different use of IF.
> In Imp.v, I only see a notation "IFB b1 THEN c1 ELSE c2". Did you try
> using this one?
>> Any clue? Is there a convenient solution with scopes?
> If notations had been exactly the same (same keywords, same case),
> scopes could have been used to modify the interpretations.
By the way, since this conversation started with the way we use notations in
the Software Foundations materials, I should say that we're very open to
better suggestions about how to use notations so they (look nicer and/or)
don't conflict with standard library stuff...
- Benjamin
- [Coq-Club] record field is "lost" if import is used, Patrice Chalin
- Re: [Coq-Club] record field is "lost" if import is used,
Hugo Herbelin
- [Coq-Club] yet another pb with Notation (from Init/Logic.v),
Jean-Francois Monin
- Re: [Coq-Club] yet another pb with Notation (from Init/Logic.v),
Hugo Herbelin
- Re: [Coq-Club] yet another pb with Notation (from Init/Logic.v), Dan Colish
- Re: [Coq-Club] yet another pb with Notation (from Init/Logic.v), Benjamin Pierce
Arthur Charguéraud
Arthur Charguéraud
Hugo Herbelin
Jean-Francois Monin
Hugo Herbelin
