- To: Chris Casinghino <chris.casinghino AT gmail.com>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] recursively non-uniform parameters in inductive types
- Date: Thu, 20 May 2010 18:05:09 +0200
Hi,
> In coq 8.1, recursively non-uniform parameters in inductive types were
> added. I think this means that, for example, the following definition
> is now accepted:
> Inductive hlist (A : Type) : Type :=
> | HNil : hlist A
> | HCons : forall B, A -> hlist B -> hlist A.
> An (hlist A) is a list where the first element (if there is one) is an
> A. I think this would have been rejected previously because I've
> identified A as a parameter, but in the recursive part of the HCons
> case I don't use the same A. Is this right?
Yes.
> My question is: what is the purpose of this feature? It's my
> (possibly incorrect) understanding that the chief reason to use a
> parameter rather than an index (or "real argument") is to get a nicer
> elimination principle. When A is a uniform parameter, the family to
> which we eliminate and the cases for each contructor do not need to
> quantify over A individually.
> But this isn't the case for "non-uniform" parameters. This intuition
> is confirmed by examining the generated elimination rules for hlist
> and a similarly defined normal list type. In the case of hlist, I
> could make A an index rather than a parameter without changing the
> elimination schemes.
> I suppose there must be (a) some other reason to prefer parameters or
> (b) an example where making a suitable index into a non-uniform
> parameter does change the elimination rules. Can someone explain?
As far as I know, the main reason for having introduced recursively
non-uniform parameters was to avoid artificially raising the universe
level of an inductive type.
Beside the reference given by Yves, I believe the feature is also used
in the "lc" Coq contribution (http://coq.inria.fr/contribs/lc.html) where
the set of lambda-terms with free variables in type X is defined by:
Inductive term (X : Type) : Type :=
| var : X -> term X
| app : term X -> term X -> term X
| abs : term (option X) -> term X.
Here both X and term X are the same type level.
If it had be defined by
Inductive term : Type -> Type :=
| var X : X -> term X
| app X : term X -> term X -> term X
| abs X : term (option X) -> term X.
then, "term X" would have been at an upper level than X (simply
because X is an argument of the constructors and then an effective
element of "term X", e.g., a projection from "term X" to Type
extracting X is possible).
Then, considering a term over terms would have not been possible.
Besides this motivation, recursively non-uniform parameters also
simplify case analysis (the rec. non-uniform param. come for free
without any need for some kind of "inversion").
This is for what I know...
Hugo Herbelin
- [Coq-Club] recursively non-uniform parameters in inductive types, Chris Casinghino
- <Possible follow-ups>
Chris Casinghino
- Re: [Coq-Club] recursively non-uniform parameters in inductive types,
Yves Bertot
Chris Casinghino
Matthieu Sozeau
- Re: [Coq-Club] recursively non-uniform parameters in inductive types, Chris Casinghino
Matthieu Sozeau
Chris Casinghino
- Re: [Coq-Club] recursively non-uniform parameters in inductive types, Hugo Herbelin
Yves Bertot
