- To: Hugo Herbelin <Hugo.Herbelin AT inria.fr>, Matthieu Sozeau <mattam AT mattam.org>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] recursively non-uniform parameters in inductive types
- Date: Thu, 20 May 2010 12:51:26 -0400
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:from:date :x-google-sender-auth:message-id:subject:to:cc:content-type :content-transfer-encoding; b=o2ILs8CmCU3eSLl8qPrHMQRh4PCd0J0F6K1tZECw91nX9C8DcypAUAuoxvwHUEHPiy frpV0zP97HvQuoxaNgBr7iSEO+SqslOCEFdL6/dhp+8bYyTGoFA/q2sVb10Q3rbJu1e5 1KHx79DuWQh3SufQB0CVyU6H/0smkqtZxCmvw=
Hello Hugo and Matthieu,
Thank you both for the thoughtful examples. I now understand some of
the ways that I have underestimated the usefulness of parameters! The
pattern matching example is particularly compelling.
--Chris
On Thu, May 20, 2010 at 12:33 PM, Matthieu Sozeau
wrote:
> Le 20 mai 2010 à 17:43, Chris Casinghino a écrit :
>> Hello Yves,
>>> You should look at the pattern-matching constructs (for instance the value
>>> of hlist_rect), the fact that the parameter does not occur among the
>>> constructors' arguments plays a role.
>> I am confused. Before sending my initial email, I observed that
>> hlist_rect doesn't change if I make A an index and an argument to each
>> constructor. That is, this alternate version of hlist is given
>> an identical hlist_rect (up to alpha-conversion):
>> Inductive hlist : Type -> Type :=
>> | HNil : forall A : Type, hlist A
>> | HCons : forall A : Type, forall B, A -> hlist B -> hlist A.
>> This was the source of my confusion, since I thought the point of
>> parameters was to get the nicer hlist_rect, as you suggest. Am I
>> missing something?
> Hi Chris,
> one nice thing about non-uniform parameters is that you don't need
> dependent
> elimination/inversion to use them, only substitution is needed. To see
> this, the
> non-uniform parameter instance must depend on the initial parameter though.
> Also you can avoid raising universe levels using parameters instead of
> arguments.
> As a slightly contrived example:
> Inductive powlist (A : Type) :=
> | pownil
> | powcons (a : A) (l : powlist (A * A)) : powlist A.
> Inductive powlistarg : Type -> Type :=
> | powargnil A : powlistarg A
> | powargcons A : forall (a : A) (l : powlist (A * A)), powlistarg A.
> (* Now, if you pattern-match on a powlist (A * B) returning an A, you can
> do:*)
> Definition powlista (p : powlist (nat * bool)) : option nat :=
> match p return option nat with
> | pownil => None
> | powcons (a, b) _ => Some a
> end.
> (* While using an p : powlistarg (A * B) this won't typecheck: *)
> Definition powlistarga (p : powlistarg (nat * bool)) : option nat :=
> | powargnil _ => None
> | powargcons A' a l => Some (fst a)
> end.
> You lose the information that A' = A * B here... so you'd need type
> equalities to make this work, or write a more generic definition on a
> "general" instance "powlistarg X". Of course, same goes for the recursive
> [l] argument which gets an overly general [powlistarg (A' * A')] type in
> the second case.
> Another interest of non-uniform type parameters is that they are readily
> extractible to Haskell/OCaml which support polymorphic recursion. They are
> also used in the FingerTree contrib.
> Hope this helps,
> -- Matthieu
- [Coq-Club] recursively non-uniform parameters in inductive types, Chris Casinghino
- <Possible follow-ups>
Chris Casinghino
- Re: [Coq-Club] recursively non-uniform parameters in inductive types,
Yves Bertot
Chris Casinghino
Matthieu Sozeau
- Re: [Coq-Club] recursively non-uniform parameters in inductive types, Chris Casinghino
Matthieu Sozeau
Chris Casinghino
- Re: [Coq-Club] recursively non-uniform parameters in inductive types, Hugo Herbelin
Yves Bertot
