coq-club - Re: [Coq-Club] recursively non-uniform parameters in inductive types
chronological Thread
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] recursively non-uniform parameters in inductive types
  • Date: Thu, 20 May 2010 18:33:20 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=sender:content-type:mime-version:subject:from:in-reply-to:date :content-transfer-encoding:message-id:references:to:x-mailer; b=vivxruuhSNQMw3Yx+d+wBFXPZdgDQEdcy2lYbDBgNIBshTZyePACVATvIqkMZZNucf 1aGl/wDeXgT2YRhPjutdzwWJ6EnfTfJrIKRwathVqxpoDxTgnTEdpSkymdxl39T8CsM6 cIrz7VbJ30/SonW1gV5zgaHX8Ovb2VfdVAOEI=
Le 20 mai 2010 à 17:43, Chris Casinghino a écrit :
> Hello Yves,
>> You should look at the pattern-matching constructs (for instance the value
>> of hlist_rect), the fact that the parameter does not occur among the
>> constructors' arguments plays a role.
> I am confused.  Before sending my initial email, I observed that
> hlist_rect doesn't change if I make A an index and an argument to each
> constructor.  That is, this alternate version of hlist is given
> an identical hlist_rect (up to alpha-conversion):
> Inductive hlist : Type -> Type :=
> | HNil  : forall A : Type, hlist A
> | HCons : forall A : Type, forall B, A -> hlist B -> hlist A.
> This was the source of my confusion, since I thought the point of
> parameters was to get the nicer hlist_rect, as you suggest.  Am I
> missing something?
Hi Chris,
  one nice thing about non-uniform parameters is that you don't need dependent
elimination/inversion to use them, only substitution is needed. To see this,
the
non-uniform parameter instance must depend on the initial parameter though.
Also you can avoid raising universe levels using parameters instead of
arguments.
As a slightly contrived example:
Inductive powlist (A : Type) :=
| pownil
| powcons (a : A) (l : powlist (A * A)) : powlist A.
Inductive powlistarg : Type -> Type :=
| powargnil A : powlistarg A
| powargcons A : forall (a : A) (l : powlist (A * A)), powlistarg A.
(* Now, if you pattern-match on a powlist (A * B) returning an A, you can
do:*)
Definition powlista (p : powlist (nat * bool)) : option nat :=
  match p return option nat with
    | pownil => None
    | powcons (a, b) _ => Some a
  end.
(* While using an p : powlistarg (A * B) this won't typecheck: *)
Definition powlistarga (p : powlistarg (nat * bool)) : option nat :=
    | powargnil _ => None
    | powargcons A' a l => Some (fst a)
  end.
You lose the information that A' = A * B here... so you'd need type
equalities to make this work, or write a more generic definition on a
"general" instance "powlistarg X". Of course, same goes for the recursive [l]
argument which gets an overly general [powlistarg (A' * A')] type in the
second case.
Another interest of non-uniform type parameters is that they are readily
extractible to Haskell/OCaml which support polymorphic recursion. They are
also used in the FingerTree contrib.
Hope this helps,
-- Matthieu
