- To: coq-club AT inria.fr
- Subject: Universe Polymorphism (Was: [Coq-Club] Proving eq_dep statements?)
- Date: Thu, 9 Sep 2010 13:27:59 +0000
- Domainkey-signature: a=rsa-sha1; c=nofws; d=googlemail.com; s=gamma; h=mime-version:date:message-id:subject:from:to:content-type; b=BGtcZ4N1rBBe1wkLedRPdgTa5I0ISEi6ThrFiH8u3XhHrPDnUhl0C6z3B47rCJ6K/+ zMGfVxWAf+9ka7bQYQsLjXo1oIb3+JMlNjn9EHn92mCCdJqR206WraOysJfs2Kt5+wa8 7jFia0c2G6xIe60yH2Y54bnMBd/t6bQAjNReA=
The lack of support for universe polymorphism is already present with
very simple examples (no need to consider the category of categories):
Inductive T : Type := t : Type -> T.
Check t T raises a universe inconsistency error. But it should be
accepted by Coq because when I define the inductive type T'
(isomorphic to T) by
Inductive T' : Type := t' : Type -> T'.
Check t T' is OK!
> Every few months, someone asks this question on coq-club. :)
This is a pity that, in spite of the many requests, universe
polymorphism is not considered seriously by Coq developers. (Please
someone, tell me I am wrong).
> there is no way to mention universe levels explicitly in source code
Even with that you would need to duplicate definitions. If you define
categories at level 0 and 1, then you have to duplicate 4 times the
definition of functors (depending on the levels of source and target
categories), 16 times the definition of natural transformation, and I
do not count the duplications for composition of functors and natural
transformations!!
> Sozeau uses type classes to define CAT
As far as I understand, it does not solve the problem at hand.
- Universe Polymorphism (Was: [Coq-Club] Proving eq_dep statements?), David Leduc
- Re: Universe Polymorphism (Was: [Coq-Club] Proving eq_dep statements?),
Bruno Barras
David Leduc
Benjamin Werner
- [Coq-Club] Re: Universe Polymorphism,
Randy Pollack
- Re: [Coq-Club] Re: Universe Polymorphism,
Dan Doel
Randy Pollack
- Re: [Coq-Club] Re: Universe Polymorphism, Dan Doel
Andreas Abel
- Re: [Coq-Club] Re: Universe Polymorphism, David Leduc
- Re: [Coq-Club] Re: Universe Polymorphism, Andreas Abel
Randy Pollack
Dan Doel
Randy Pollack
Benjamin Werner
David Leduc
Bruno Barras
