- To: "coq-club" <coq-club AT inria.fr>
- Subject: re: [Coq-Club] about the exercise 6.46 in Coq Art book
- Date: Sun, 12 Sep 2010 19:44:26 +0800
Hello coq user:
Definition first_of_htree :
forall (A:Set) (n:nat), htree A n -> htree A (S n) -> htree A n.
intros A n v t.
generalize v.
change (htree A (pred (S n)) -> htree A (pred (S n))).
case t.
intros x v'; exact v'.
intros p x t1 t2 v'; exact t1.
Defined.
I think "first_of_htree" is a function. Is it necessary for the definiionare
to have the corresponding proof scripts " intros A.... exact t1."
"first_of_three" should take 2 arguments-- one of is type of " htree A n" ,
and the other is type of " htree A (S n)"-- and then can give us the result
type of "htree A n".
Hence, the proof scripts should be replaced by the form of " := ... "
instead. and ":=..." should provide the process for how to apply the 2
arguments and how to calculate the associated results.
What's the problem about my opinion?
Thanks for your any reply.
2010-09-12
Qgxu
Date: 2007-11-20 21:18:07
To: Coq Club
Cc:
Subject: [Coq-Club] about the exercise 6.46 in Coq Art book
Dear all
I am working on the exercise 6.46 in Coq Art.
Inductive htree (A:Set) : nat -> Set :=
| hleaf : A -> htree A 0
| hnode : forall n:nat, A -> htree A n -> htree A n -> htree A (S n).
intros A n v t.
generalize v.
case t.
Defined.
After first_of_htree is defined, I used the Print command to see the
detail of first_of_htree, I got this:
1) first_of_htree =
2) fun (A : Set) (n : nat) (v : htree A n) (t : htree A (S n)) =>
3) match t in (htree _ n0) return (htree A (pred n0) -> htree A (pred n0))
with
4) | hleaf _ => fun v' : htree A (pred 0) => v'
5) | hnode p _ t1 _ => fun _ : htree A (pred (S p)) => t1
6) end v (*this v confused me*)
7) : forall (A : Set) (n : nat), htree A n -> htree A (S n) -> htree A n
I do not know the exact meaning of "end v" in the sixth line.
I defined a first_of_htree' similar to first_of_htree as this:
1) first_of_htree' =
2) fun (A : Set) (n : nat) (_ : htree A n) (t : htree A (S n)) =>
6) end
8) htree A n ->
9) htree A (S n) -> htree A (pred (S n)) -> htree A (pred (S n))
the two definitions differed only in the sixth line, one has "v" and
one does not. This "v" makes their types different.
Could any one explain why?
btw, I search the manual using key word "match", it seems that, all
the "end"s corresponding to "match" are end up with nothing.
Hai Wan
Bug reports: http://logical.futurs.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
- re: [Coq-Club] about the exercise 6.46 in Coq Art book, 许庆国
- Re: [Coq-Club] about the exercise 6.46 in Coq Art book,
Adam Chlipala
- Re: [Coq-Club] about the exercise 6.46 in Coq Art book, Pierre Casteran
Adam Chlipala
