- To: Andreas Abel <andreas.abel AT ifi.lmu.de>
- Cc: coq-club AT inria.fr, agda AT lists.chalmers.se
- Subject: Re: [Coq-Club] Re: Universe Polymorphism
- Date: Thu, 16 Sep 2010 14:28:50 -0400
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=from:to:subject:date:user-agent:cc:references:in-reply-to :mime-version:content-type:content-transfer-encoding:message-id; b=xMJKmfcHxUGJLZUS8qIFCkot55tpjbVMoiYpbkcUWrgxWrroZcH8IY8szLV4ERTbZZ i14ld2Lyim30kKygTC4pcWtKztNdjc9kaxZLotJSGlGup2LVINEzCHHydPDsIDuSp9BU F9UDDmJsncQtcaOTVIKE2fJLxLJw8FPwBsA0E=
(I'm copying the Agda list with this, since the conversation may be of
interest there, too.)
On Thursday 16 September 2010 12:34:53 pm Andreas Abel wrote:
> thanks for your answer and the pointer to the EPTS paper. I had not
> seen it so far, I always refer to a paper by Barras and Bernardo
> published at the same conference (FoSSaCS 2008) with nearly the same
> content!
In that case, one of the author's did an entire thesis on the subject:
http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.154.5619
Including extending the erasure/irrelevance stuff to inductive types,
erasability analysis (which may or may not be what you asked for later in
your
mail), and thoughts on proof irrelevance (although, I'm personally not
convinced that this sort of erasability captures that notion precisely).
> In MiniAgda, I am using EPTSs and I started implementing them for
> Agda, although there are some issues to clarify when you scale up from
> PTSs to a real dependent type theory with types defined by cases.
Yeah. The thesis above presents an analysis of a type theory with strong
eliminators and erasure. I'm not sure how hard it would be to translate that
to Agda's pattern-matching-as-primitive theory. Hopefully not very.
> - PTS rules can be used to forbid your embed function, if you put
> Level outside of the Set tower.
> If TLevel is the sort of Level, then just do not add rules like (Set
> i, Level, Level).
Yeah, that's true. The theme of the EPTS papers/thesis, though, is that
irrelevance/erasability/parametricity should not (necessarily) be intrinsic
to
types; it should be based on use. So, I thought it would be similarly nice if
one could make universe polymorphism always parametric while not making any
types intrinsically irrelevant. And I believe my scheme achieves that (it was
the more fully baked idea).
> Finding out whether something is a universe is not completely trivial
> in Coq or Agda, because of types defined by cases and cumulativity.
Yeah, you're right. Data in higher universes is a problem.
data T : Set 5 where
t u : T
foo : T -> Nat
foo t = 0
foo u = 1
T is obviously relevant in foo, but T : Set 5 and Nat : Set 0, 5 > 0. I
obviously hadn't thought that one through well enough. :)
> Regarding the Set\omega: It is forbidden in Agda, so some things
> cannot be expressed. But if we add it to Agda and internally use a
> Set(\omega + 1) to type Set\omega, would there not again things you
> cannot express?
> Of course, there is no reason why the hierarchy should stop at \omega,
> you could go to higher ordinals... :-) However, maybe we should wait
> with this until practical applications appear that use more than 3
> levels. :-)
There would, of course, be things you can't express. Adding a Set(ω+1) could
well have the same problems, because the problem isn't a lack of a universe
above Setω, but an asymmetry with its inhabitants. Currently, we have
Π i:Level. T[i] : Setω, for T[i] : Set (f i)
but not
Σ i:Level. T[i]
And thus we can write:
(i : Level) -> T[i] -> R
but not
(Σ i:Level. T[i]) -> R
even though it's isomorphic to the former. I don't mind the hierarchy having
a
top as it does, and I think omega is a good place to stop (it's where I
stopped in my own interpreter). I'm okay with not allowing:
(S : Setω) -> ...
But, to put inductive types in Setω (which would be okay, with caveats, I
think), we have to be able to mention it, due to Agda's syntax:
data T : Setω where ...
The usage there is not quantification over the universe, but akin to:
((i : Level) -> Set i) : Setω
Cheers,
-- Dan
- Re: Universe Polymorphism (Was: [Coq-Club] Proving eq_dep statements?), (continued)
Benjamin Werner
- [Coq-Club] Re: Universe Polymorphism,
Randy Pollack
- Re: [Coq-Club] Re: Universe Polymorphism,
Dan Doel
Randy Pollack
- Re: [Coq-Club] Re: Universe Polymorphism, Dan Doel
Andreas Abel
- Re: [Coq-Club] Re: Universe Polymorphism, David Leduc
- Re: [Coq-Club] Re: Universe Polymorphism, Andreas Abel
Randy Pollack
Dan Doel
Randy Pollack
Benjamin Werner
