- To: Xinyu Jiang <xj27 AT pantheon.yale.edu>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] An axiom about parametricity
- Date: Wed, 22 Sep 2010 17:52:47 +0200
Le Wed, 22 Sep 2010 22:22:11 +0800,
Xinyu Jiang
a écrit :
> Hi all,
> I would like to add an axiom somehow like:
> "forall (F : Type -> Type) (f g : forall t, F t) (t : Type), f t =
> g t -> f = g"
> to Coq. It seems to be reasonable because of the parametricity of
> Coq's logic. But I wonder if the axiom is indeed consistent with Coq.
> If so, would it collide against other axioms like exclusive of the
> middle? If not, what would the counter example be like? Thanks very
> much.
That is inconsistant with many logics:
Variables f g: Type -> nat.
Hypothesis f_spe1: 0 = f bool.
Hypothesis f_spe2: 1 = f nat.
Hypothesis g_spe1: 0 = g bool.
Hypothesis g_spe2: 0 = g nat.
Variable Absurd: forall (F : Type -> Type) (f g : forall t, F t)
(t : Type), f t = g t -> f = g.
Goal False.
generalize (Absurd (fun (_: Type) => nat) f g bool).
destruct f_spe1; destruct g_spe1.
intro.
assert (K := H (refl_equal _)).
assert (L := g_spe2).
destruct K.
destruct f_spe2.
discriminate.
Qed.
In fact your axioms states that if "f" and "g" are equal in one point,
then they are equal; it looks a little like to "proof irrelevance" but
in "Type".
But I know that axiom-free inhabitants of "Type -> Type" in Coq are
constant functions, as matching is not allowed for Type;
that means that such functions cannot inspect their argument to produce
something depending on it; and can only be constant functions.
As you cannot produce axiom-free counter examples of
"CST: forall (F: Type -> Type) (f: forall t, F t)
(t1 t2: Type), f t1 = f t2",
I assume that "CST" is a weird but would be consistant if were well
typed (let us say using JMeq).
And with such a lemma, you might prove your axiom, using
extensionnality.
In brief, I think that if "CST" and "Extensionnality" are consistant,
then your axiom should be.
But as I am pretty sure that
is consistent with Coq (axiom-free) logic, your axiom certainly cannot
be proved in Coq.
- [Coq-Club] An axiom about parametricity, Xinyu Jiang
- Message not available
Xinyu Jiang
- Re: [Coq-Club] An axiom about parametricity, Chad E Brown
- Re: [Coq-Club] An axiom about parametricity, AUGER Cedric
Bruno Barras
- Re: [Coq-Club] An axiom about parametricity, Thorsten Altenkirch
Bruno Barras
Xinyu Jiang
- Re: [Coq-Club] An axiom about parametricity, Arthur Charguéraud
Taral
- <Possible follow-ups>
- Re: [Coq-Club] An axiom about parametricity, xinyu . jiang
