coq-club - Re: [Coq-Club] An axiom about parametricity
chronological Thread
  • To: Chad E Brown <cebrown2323 AT yahoo.com>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] An axiom about parametricity
  • Date: Fri, 24 Sep 2010 02:59:13 -0400
Hi,
Thank you and everyone else. It my fault to ignore the apparent
mistake. In fact, what I want is not a such general (and wrong)
axiom. And the addition to Coq I need can be simplified and explained here:
Suppose I have a HOAS representation of a part of an (impredicative) assertion
language:
Inductive assert (t : Type) : Type :=
| avar : t -> assert t
| aand : assert t -> assert t -> assert t
| aexist : (t -> assert t) -> assert t.
Then I would like to have such an axiom:
"forall (f g : forall t, t -> assert t) (t : Type), f t = g t -> f = g"
which is a specific version of the wrong axiom I proposed.
The counter example which falsify the general version of the axiom does not
work here, because "F" is now "fun t => t -> assert t", which always returns
an
inhabited type not isomorphic to "False". Would this kind of specific axioms
inconsistant to Coq again? Thanks very much!
                                         Xinyu Jiang
Quoting Chad E Brown
<cebrown2323 AT yahoo.com>:
> Hi Xinyu, and all,
> The axiom as you gave it is inconsistent with Coq.  A proof is below.
>  Maybe you
> meant something else?
> Axiom pa : forall (F : Type -> Type) (f g : forall t, F t) (t :
> Type), f t = g t
> -> f = g.
> Definition f_ (X : Type) : Type := X -> False.
> Definition g_ (X : Type) : Type := False -> X.
> Goal False.
> cut (f_ = g_). intros e.
> cut (g_ True). rewrite <- e. auto.
> unfold g_. auto.
> apply (pa (fun X => Type) f_ g_ False).
> auto.
> Qed.
> - Chad
> ________________________________
> From: Xinyu Jiang
> <xj27 AT pantheon.yale.edu>
> To:
> Sent: Wed, September 22, 2010 4:22:11 PM
> Subject: [Coq-Club] An axiom about parametricity
> Hi all,
>  I would like to add an axiom somehow like:
>  "forall (F : Type -> Type) (f g : forall t, F t) (t : Type), f t = g
> t -> f =
> g"
>  to Coq. It seems to be reasonable because of the parametricity of
> Coq's logic.
> But I wonder if the axiom is indeed consistent with Coq.
> If so, would it collide against other axioms like exclusive of the middle?
> If
> not, what would the counter example be like? Thanks very much.
