coq-club - Re: [Coq-Club] An axiom about parametricity
chronological Thread
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] An axiom about parametricity
  • Date: Wed, 22 Sep 2010 20:11:57 +0200
On 09/22/2010 05:55 PM, AUGER Cedric wrote:
Le Wed, 22 Sep 2010 22:22:11 +0800,
Xinyu
Jiang<xj27 AT pantheon.yale.edu>
  a Ã©crit :
Hi all,
   I would like to add an axiom somehow like:
   "forall (F : Type ->  Type) (f g : forall t, F t) (t : Type), f t =
g t ->  f = g"
   to Coq. It seems to be reasonable because of the parametricity of
Coq's logic. But I wonder if the axiom is indeed consistent with Coq.
If so, would it collide against other axioms like exclusive of the
middle? If not, what would the counter example be like? Thanks very
much.
Variable Absurd: forall (F : Type ->  Type) (f g : forall t, F t)
          (t : Type), f t = g t ->  f = g.
In fact your axioms states that if "f" and "g" are equal in one point,
then they are equal; it looks a little like to "proof irrelevance" but
in "Type".
Right. And it clearly does not hold: True and False are quite different types: you can prove True, and if they were equal you could prove False by rewriting.
But I know that axiom-free inhabitants of "Type ->  Type" in Coq are
constant functions, as matching is not allowed for Type;
No. identity is not a constant function when the domain has at least two elements :o)
So (Absurd (fun _=>Type) (fun P => P) (fun _ => False) False
    (@eq_refl Type False))
is a proof of (fun P => P) = (fun _ => False)
(they match on t=False)
Then (fun P=>P) True = (fun _=>False) True by rewriting.
You've deduced True = False.
I leave the proof of False as an exercise.
I don't know what you mean by "parametricity of Coq's logic". It is true that you cannot do some case-analysis on objects in Type, but dependent types and the complex language on types will not give you the same "theorems for free" as for system F...
Bruno Barras.
