- To: Coq Club <coq-club AT inria.fr>
- Subject: [Coq-Club] Deferring proofs in definitions
- Date: Thu, 7 Oct 2010 22:25:13 -0700
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=from:to:subject:date:user-agent:mime-version:content-type :content-transfer-encoding:message-id; b=f7Ond0Rm0YzpOQtMltc7HEovJaoXaFjQiyK4oUGWslmI0lVsfqLnQ3X0x7qM8pMW62 2qTbxyLiq4pkAZJQ+12JGfErwHLWbJoWakkwRRp/vgyLay9SWHCVX6XMSsXp4QN6nQQm JukZ0EdfjudHBKjb8cbRHqUCPhZXNhE7u8F7Q=
Sorry if this is a basic question, but I couldn't find any answer in the
manual... Say I want to make a definition of some function, but it involves
passing in proofs into some of the subterms. Is there a way I could leave
those proofs to be filled in by the proof assistant, while making other parts
of the definition explicit? For a simple example of what I mean:
Definition inclusion_fun {X:Type} (S T:Ensemble X)
(_:Included _ S T) (x:{x:X | In _ S x}) :
{x:X | In _ T x} :=
match x with
| exist x0 _ => exist _ x0 ?
end.
So I'd want the proof assistant to come up with a goal of "In X T x0" with
appropriate variables and hypotheses in the upper section (including "H :
Included X S T" and "H0 : In X S x0"), to fill in the "?".
Certainly, I could leave out the body and use the proof assistant to
construct
the whole thing; but then, on reading through the .v file, it would be
unclear
what the function is actually returning. On the other hand, I could put in
all those proofs by hand; in the case above, that would be easy enough, but
in
general that will tend to be cumbersome. Or I could prove mini-lemmas
beforehand that prove exactly the conditions I need to fill in the gaps; but
that would also tend to distract attention from the important results in a .v
file.
Such a feature would also be useful for leaving gaps in a "pose" definition,
again generating the appropriate subgoals of the current goal.
On a related note, is there any way to generate a subgoal which will become a
transparent definition once its proof is done? It seems that "assert" always
generates an opaque definition, and I don't see any alternative that
generates
a transparent definition.
Sometimes I've worked around this by having functions that return a sigma-
type. Then the ability to e.g. "destruct inclusion_fun in ..." is immensely
useful. But sometimes that tends to be a little cumbersome, too...
Definition inclusion_fun {X:Type} (S T:Ensemble X):
Included _ S T -> {f : {x:X | In _ S x} -> {x:X | In _ T x} |
forall x:{x:X | In _ S x}, proj1_sig (f x) = proj1_sig x}.
Defined.
That's already a bit of a mouthful, and tends to get even more so if there
are
multiple cases for the definition.
Daniel Schepler
- [Coq-Club] Deferring proofs in definitions, Daniel Schepler
- Re: [Coq-Club] Deferring proofs in definitions, Christian Doczkal
AUGER Cedric
Stéphane Lescuyer
Stéphane Lescuyer
- Re: [Coq-Club] Deferring proofs in definitions, Daniel Schepler
- Message not available
Stéphane Lescuyer
Stéphane Lescuyer
Stéphane Lescuyer
Stéphane Lescuyer
