- To: St�phane Lescuyer <stephane.lescuyer AT inria.fr>
- Cc: AUGER Cedric <Cedric.Auger AT lri.fr>, Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Deferring proofs in definitions
- Date: Fri, 8 Oct 2010 21:58:17 -0700
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=from:to:subject:date:user-agent:cc:references:in-reply-to :mime-version:content-type:content-transfer-encoding:message-id; b=dZ1gJiFNOv1/KiQ+Jy3WRq9Q5aLxTx5PuEUtrlFzsOxON7uvyadKHHPx1qLgNYUL2p tnM+GVslk53O1aGxNnXlNdi4HX6lSGP90hvkXzZedynto2BXXVRUXSns6pWa6O83BTfY EoV3wJ1vD6mRPdltb1cq0r81qp7UEBm4iWfbM=
On Friday 08 October 2010 01:58:51 Stéphane Lescuyer wrote:
> > I second Cedric's answer, you should try refine or Program. Note that
> > there is probably a nicer way to do wha
> Sorry, premature sending :)
> So I was saying, unless this is really what you want to do, you should
> maybe try and rethink what you're doing in order to avoid mixing
> definitions and proofs.
> A final note: you can use refine and still have proofs opaque, by
> using the abstract tactic: abstract (<tactic>) applies tactic, which
> should solve the current goal, and saves it as an opaque lemma. The
> downside is you need to prove every subgoal in one tactic, or one
> chain of tactic. If you have trouble with that particular point, ask
> Adam Chlipala :)
> S.
Thanks for all the replies, it looks like the "refine" tactic is pretty much
exactly what I was asking for, at least for definitions...
Definition inclusion_fun {X:Type} (S T:Ensemble X) (_:Included _ S T)
(x:{x:X | In _ S x}) : {x:X | In _ T x}.
intros.
refine (match x with
| exist x0 _ => exist _ x0 _
end).
auto with sets.
Defined.
Unfortunately, it looks like if I try to do a "refine (let g := fun ... in
_)"
with holes, the g becomes opaque when filling out the body of the let. To
give
extracts of some recent work I've done:
Definition injective {X Y:Type} (f:X->Y) :=
forall x1 x2:X, f x1 = f x2 -> x1 = x2.
Definition surjective {X Y:Type} (f:X->Y) :=
forall y:Y, exists x:X, f x = y.
Definition bijective {X Y:Type} (f:X->Y) :=
injective f /\ surjective f.
Inductive FiniteT : Type->Prop :=
| empty_finite : FiniteT False
| add_finite : forall X:Type, FiniteT X -> FiniteT (option X)
| bij_finite : forall (X Y:Type) (f:X->Y),
FiniteT X -> bijective f -> FiniteT Y.
Lemma finite_inj_surj: forall (X:Type) (f:X->X),
FiniteT X -> injective f -> surjective f.
Proof.
intros.
revert f H0.
induction H.
(* case False *)
intros; red; intro.
induction y.
(* case option X, assuming true for X *)
intros.
(* remember (f None) as f0; destruct f0 *)
refine ((match (f None) as f0 return (f None = f0 -> _) with
| Some a => fun (Heqf0:_) => _
| None => fun (Heqf0:_) => _
end) (refl_equal _)).
(* case f None = Some a *)
(* pose (g := ...) *)
refine (let g := fun (x:X) => match f (Some x) with
| Some y => y
| None => a
end in _).
assert (surjective g).
apply IHFiniteT.
(* ... finish the proof of this case *)
admit.
admit.
(* case f None = None *)
(match f (Some x) as fx return (f (Some x) = fx -> _) with
| Some y => fun _ => y
| None => fun (Heqfx:_) => False_rect _ _
end) (refl_equal _) in _).
rewrite <- Heqf0 in Heqfx.
apply H0 in Heqfx.
discriminate Heqfx.
So for the first refinement creating a local definition of g, it created a
transparent definition and I was able to complete the proof of that case.
But
for the second refinement, I was left with an opaque "g : X -> X" which was
useless. In both cases, g is just an auxiliary function to use in the
inductive hypothesis, and wouldn't be of much interest outside the proof.
Daniel Schepler
- [Coq-Club] Deferring proofs in definitions, Daniel Schepler
- Re: [Coq-Club] Deferring proofs in definitions, Christian Doczkal
AUGER Cedric
Stéphane Lescuyer
Stéphane Lescuyer
- Re: [Coq-Club] Deferring proofs in definitions, Daniel Schepler
- Message not available
Stéphane Lescuyer
Stéphane Lescuyer
Stéphane Lescuyer
Stéphane Lescuyer
