- To: St�phane Lescuyer <stephane.lescuyer AT inria.fr>
- Cc: AUGER Cedric <Cedric.Auger AT lri.fr>, Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Deferring proofs in definitions
- Date: Sat, 9 Oct 2010 11:04:54 -0700
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=from:to:subject:date:user-agent:cc:references:in-reply-to :mime-version:content-type:content-transfer-encoding:message-id; b=DIHNC81ad+XvX0p1SKbGJw5tzSbzFVI8pcaDsQSXNdRsWL9Oo5N8fYgNLkbLApHo4G Jb2nfph92Qmml/jOOM9W0BhaBqS+qGnfX4Bfq7QRDW9QBDUslJvRSnDXp9YaUT/OYKAF 0aYBWoAV1ktqJXH0c+JgroxMmWNrl8vCW8IUI=
On Saturday 09 October 2010 02:04:51 Stéphane Lescuyer wrote:
> > So for the first refinement creating a local definition of g, it created
> > a transparent definition and I was able to complete the proof of that
> > case. But for the second refinement, I was left with an opaque "g : X
> > -> X" which was useless. In both cases, g is just an auxiliary function
> > to use in the inductive hypothesis, and wouldn't be of much interest
> > outside the proof.
> Yes if some part of the let contained proofs, then it is made opaque,
> that's why [g] is transparent in the first case and opaque in the
> second.
> I see two workarounds to this:
> - you say that defining g outside the proof wouldn't make much sense,
> and you're right, but you can prove the "hole" in g as an intermediate
> result in the proof and then you don't need refine anymore. In your
> case, you need to know that [f (Some x) <> None] for all x:
> (* case f None = None *)
> assert (Habs : forall x, f (Some x) = None -> False).
> intros; assert (Some x = None). apply Hinj; congruence. discriminate.
> set (g := fun x => match f (Some x) as a return f (Some x) = a -> X with
> | Some x' => fun _ => x'
> | None => fun abs => False_rect _ (Habs x abs)
> end (refl_equal _)).
> (* - extra part which I suggest *)
> assert (gdef : forall x, f (Some x) = Some (g x)).
> intro x; unfold g; set (Z := Habs x); clearbody Z.
> destruct (f (Some x)); auto; contradiction (Z (refl_equal _)).
> clearbody g.
> You can thus introduce the function g without holes, with set or
> pose, and since reasoning with the definition of g will be slightly
> awkward (because of the dependent elimination), I suggest that you
> prove an indirect definition of g right away, once and for all, and
> make g opaque afterwards.
I think that's the workaround I already used in my proof. That really
reduces
the usefulness of refine, though.
> - the second workaround is just to use refine to introduce not only g,
> but g along with its specification, ie. g with what I called gdef
> above, so basically you introduce {g | forall x, f (Some x) = Some (g
> x)} instead of simply g and then you don't care about what g looks
> like. Refine might not allow very complex holes though...
As I already noted, that would tend to get cumbersome if g is defined by
cases.
My specification of the first g, if it had required holes, would be something
like:
forall x:X, {y:X | f (Some x) = Some y \/ (f (Some x) = None /\ y = a)}
> Hope this helps,
> Stéphane
> PS: with your definition of surjectivity, unless I'm mistaken, there
> is no hope of proving the theorem for the bij case in axiom-free CIC
> because you won't be able to build the inverse of a bijective
> function. Using "Definition surjective f := forall y, {x | f x = y}."
> would make it possible.
Well, my primary interest in coq is in formalizing mathematical proofs and
not
in computability, so I don't hesitate to use things like
constructive_definite_description, functional_extensionality,
proof_irrelevance, etc. On the other hand, as a specialist in algebraic
geometry, I *am* interested in which results can be proved in a topos, i.e.
without classic or choice. And the statement that every surjective function
has a right inverse as above is essentially equivalent to choice. (Although
I
did prove a finite_choice without assuming choice, so the two are equivalent
modulo c_d_description for finite codomains.) But you could replace
"bijective" with "invertible" in the definition of FiniteT -- I already
proved
they're equivalent modulo c_d_description and the proof of finite_inj_surj
would probably become CIC axiom-free.
Inductive invertible {X Y:Type} (f:X->Y) : Prop :=
| inverse_func_intro : forall g:Y->X,
(forall x:X, g (f x) = x) -> (forall y:Y, f (g y) = y) ->
invertible f.
Actually, it might not be a bad idea to make that replacement in any case --
it would save me a lot of applications of bijective_equiv_invertible, and in
proving things like "FiniteT X -> FiniteT Y -> FiniteT (X+Y)" I was
essentially constructing inverse functions to "option (X + Y) -> X + option
Y"
piecemeal anyway. I'd just have to make the inverses explicit, which is a
good thing.
Daniel Schepler
- [Coq-Club] Deferring proofs in definitions, Daniel Schepler
- Re: [Coq-Club] Deferring proofs in definitions, Christian Doczkal
AUGER Cedric
Stéphane Lescuyer
Stéphane Lescuyer
- Re: [Coq-Club] Deferring proofs in definitions, Daniel Schepler
- Message not available
Stéphane Lescuyer
Stéphane Lescuyer
Stéphane Lescuyer
Stéphane Lescuyer
