- To: St�phane Lescuyer <stephane.lescuyer AT polytechnique.org>
- Cc: Alexandre Pilkiewicz <alexandre.pilkiewicz AT polytechnique.org>, Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] [Type Classes]: avoid duplication of instances
- Date: Wed, 13 Oct 2010 15:14:37 -0400
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:cc:content-type :content-transfer-encoding; b=VIEvZBNTeXZb2Hs6i+57xrpYQbM4AbMuEw3Qx4zVcyzUaIlbo97AxXGqMTwNWrYDlR 8I61yoHED2eETc7QcT1DHRb3gs2Z1TCmwMpCpmjRfz1YgV2kfmL92uT+X/1tNdQmMZgg aGwdC2827HPztgzV9sr1r05RUOGeVAXtstous=
2010/10/12 Stéphane Lescuyer
<stephane.lescuyer AT polytechnique.org>:
> 1 subgoal
> A : Type
> EqA : EqDec A
> x : A
> y : A
> H : equal x y = true
> x = y
>> destruct (eq_dec x y).
Hi Stéphane,
I am rather disappointed to find out that this only works in this way
in Coq 8.2. In Coq 8.3rc1, to achieve the same effect, you must write
destruct (@eq_dec A EqA x y).
While this doesn't entirely negate the usefulness of this technique, I
really wish it was as easy in 8.3 as 8.2. What happened? Is there
some new vernacular command I have to use to get 8.3 to cooperate?
- Aaron
- [Coq-Club] [Type Classes]: avoid duplication of instances, Alexandre Pilkiewicz
- Re: [Coq-Club] [Type Classes]: avoid duplication of instances,
Stéphane Lescuyer
Stéphane Lescuyer
- Re: [Coq-Club] [Type Classes]: avoid duplication of instances, Alexandre Pilkiewicz
Aaron Bohannon
Stéphane Lescuyer
Aaron Bohannon
- Re: [Coq-Club] [Type Classes]: avoid duplication of instances, Stéphane Lescuyer
- Re: [Coq-Club] [Type Classes]: avoid duplication of instances, Aaron Bohannon
Aaron Bohannon
Stéphane Lescuyer
Stéphane Lescuyer
Stéphane Lescuyer
