- From: St�phane Lescuyer <stephane.lescuyer AT polytechnique.org>
- To: Aaron Bohannon <bohannon AT cis.upenn.edu>
- Cc: Alexandre Pilkiewicz <alexandre.pilkiewicz AT polytechnique.org>, Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] [Type Classes]: avoid duplication of instances
- Date: Wed, 13 Oct 2010 21:17:58 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:cc:content-type :content-transfer-encoding; b=XNkuv1WBlFInzq+HEyjQyU4XGtqDrlPZu2r2yz9DMH/umQ6Z9MUQ1gn/5/knFyc4IT rC6zwt4yNSQvS8iYBPS44yiFkJBT184WmJCIKGaWrd4p1WBDIb1SFhCmYCxtvN5uX+f0 1rzeBFCrY9Q7MggDhr6+Fmsb6+RLrpnLbAdGM=
Don't worry, it's just Bug #2222 :-) it has been corrected last week
only, so it was still there in the release candidate. The trunk
version of branch 8.3 should be ok.
Stéphane
2010/10/13 Aaron Bohannon
<bohannon AT cis.upenn.edu>:
> 2010/10/12 Stéphane Lescuyer
>Â <stephane.lescuyer AT polytechnique.org>:
>> 1 subgoal
>> A : Type
>> EqA : EqDec A
>> x : A
>> y : A
>> H : equal x y = true
>> x = y
>>> destruct (eq_dec x y).
> Hi Stéphane,
> I am rather disappointed to find out that this only works in this way
> in Coq 8.2. In Coq 8.3rc1, to achieve the same effect, you must write
> destruct (@eq_dec A EqA x y).
> While this doesn't entirely negate the usefulness of this technique, I
> really wish it was as easy in 8.3 as 8.2. What happened? Is there
> some new vernacular command I have to use to get 8.3 to cooperate?
> - Aaron
I'm the kind of guy that until it happens, I won't worry about it. -
R.H. RoY05, MVP06
- Re: [Coq-Club] [Type Classes]: avoid duplication of instances, (continued)
Stéphane Lescuyer
Stéphane Lescuyer
- Re: [Coq-Club] [Type Classes]: avoid duplication of instances, Alexandre Pilkiewicz
Aaron Bohannon
Stéphane Lescuyer
Aaron Bohannon
- Re: [Coq-Club] [Type Classes]: avoid duplication of instances, Stéphane Lescuyer
- Re: [Coq-Club] [Type Classes]: avoid duplication of instances, Aaron Bohannon
Aaron Bohannon
Aaron Bohannon
Stéphane Lescuyer
Stéphane Lescuyer
Stéphane Lescuyer
