coq-club - [Coq-Club] running out of memory with big proof objects
chronological Thread
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: [Coq-Club] running out of memory with big proof objects
  • Date: Tue, 19 Oct 2010 18:10:14 -0400
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:date:x-google-sender-auth:message-id:subject :from:to:content-type; b=UwCg88KtsSPmtcA0cs+Rj99SUoVgiOoYtKNUhA+if5u+1C+gbmrv6VDLAflNs3BfDJ vd2zTaT3MICzFD9kPXr+QkvPCZqzkpNKRAdEboF4dmMAuCn+OgLcGImovZ2OBa8pvU+E SGuGEYMb0hVFL7Txn4uIDebg26TObx4/j9zcM=
Hi, I am running into a performance issue.  I have a moderately large
but straightforward proof.  Basically, it breaks down into 256 cases,
almost all of which are solved by one use of the "inversion" tactic
(that does not generate additional subgoals), followed by a use of the
"congruence" tactic.  It is easy to write a tactic definition to
finish the whole proof at once.  It takes about 20 seconds on my
machine to run the tactic in CoqIDE, and get "Proof completed."  If I
type "Qed," it takes about another 20 seconds to complete the proof.
If I say "Defined," CoqIDE will crash after about 20 seconds (coqc on
the command-line does not crash but doesn't work any faster).
It seems like something must be wrong here.  Is there something I
should be using instead of "inversion H; congruence"?  If nothing
else, is there way to give CoqIDE more memory so it doesn't crash?
 - Aaron
