- To: Hai WAN <wan.whyhigh AT gmail.com>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] how to state a hypothesis with the help of another hypothesis
- Date: Sat, 06 Nov 2010 13:06:09 -0400
Hai WAN wrote:
Variable V : Set.
Variable D : V->Set.
Definition States := forall v:V, D v.
Variable t : V.
Hypothesis t_nat :
D t = nat.
Hypothesis t_full :
forall n:nat, exists s:States, s t = n.
Of course, I get an error message saying that (s t) is of type (D t), while n is of type nat.
I already have hypothesis t_nat stating "D t = nat". How to define t_full with the help of t_nat?
There are two main options. First, you can use a cast:
Hypothesis t_full :
forall n:nat, exists s:States, match t_nat in _ = T return T with refl_equal => s t end = n.
Second, you can use an alternate notion of equality, e.g., [JMeq]:
Require Import JMeq.
Hypothesis t_full :
forall n:nat, exists s:States, JMeq (s t) n.
I prefer the former approach, wherever it doesn't lead to too much inconvenience. The main issues here are discussed in Chapter 9 of CPDT (http://adam.chlipala.net/cpdt/).
- [Coq-Club] how to state a hypothesis with the help of another hypothesis, Hai WAN
- Re: [Coq-Club] how to state a hypothesis with the help of another hypothesis, Adam Chlipala
