- To: Coq Club <coq-club AT inria.fr>
- Subject: [Coq-Club] Program Fixpoint and finite sets
- Date: Mon, 8 Nov 2010 17:19:39 +0000
Dear all,
I am experimenting with Program Fixpoint feature of Coq for building
functions on finite sets. I have implemented this simpl function
[add_to_set_not_in], whose termination criteria was very easy to prove. The
code is the following:
Module FSetsProgram(X:FSetInterface.WS).
Import X.
Module Xp := Properties(X).
Module Xd := Decide(X).
Program Fixpoint add_to_set_not_in (S:X.t)(H:X.t) { measure X.cardinal S} :
X.t :=
match X.choose S with
| None => X.empty
| Some x => match Xp.In_dec x H with
| left _ => add_to_set_not_in (X.remove x S) H
| right _ => X.add x (add_to_set_not_in (X.remove x S) H)
end
end.
Next Obligation.
symmetry in Heq_anonymous.
apply X.choose_1 in Heq_anonymous.
rewrite <- (Xp.remove_cardinal_1 Heq_anonymous).
omega.
Defined.
Next Obligation.
omega.
Defined.
Lemma teste : X.Equal (add_to_set_not_in X.empty X.empty) X.empty.
Proof.
admit. (* struck here *)
Qed.
End FSetsProgram.
I am currently struck in the lemma [teste], although it is a very simple
property. Is there any standard tricks for reasoning about terms built using
the Program Fixpoint construction?
Any help is very appreciated :)
Best reagards,
David.
- [Coq-Club] Program Fixpoint and finite sets, David Pereira
- Re: [Coq-Club] Program Fixpoint and finite sets, David Pichardie
- [Coq-Club] Binding variables within nested matches,
Ben Moseley
- Re: [Coq-Club] Binding variables within nested matches, Adam Chlipala
- <Possible follow-ups>
Xavier Leroy
Stéphane Lescuyer
- Re: [Coq-Club] Program Fixpoint and finite sets, Matthieu Sozeau
Stéphane Lescuyer
