- From: St�phane Lescuyer <stephane.lescuyer AT inria.fr>
- To: Xavier Leroy <Xavier.Leroy AT inria.fr>
- Cc: David Pereira <dpereira AT liacc.up.pt>, Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Program Fixpoint and finite sets
- Date: Tue, 9 Nov 2010 11:33:07 +0100
Just to extend on Xavier's answer, if you are only using Program for
the non-structural induction but not for programming with dependent
types, you should rather try using Function instead. The difference is
that Function will create a handy "unfolding" equation which makes it
easy to reason about your function after it has been defined.
Also, beware of using Xp.In_dec instead of X.mem in your functions.
S.
On Tue, Nov 9, 2010 at 10:49 AM, Xavier Leroy
wrote:
> David Pereira wrote:
>> I am experimenting with Program Fixpoint feature of Coq for building
>> functions on finite sets. [...] Is there any standard tricks for
>> reasoning about terms built using the Program Fixpoint construction?
> In the case of "measured" or well-founded functions, none that I know of :-(
> As far as I know, the idiomatic way to use Program Fixpoint {measure}
> is to return an "informative" type {x | P x} where P captures
> everything you'd ever want to know later about the result of the function.
> E.g. in your case,
> Program Fixpoint add_to_set_not_in (S:X.t)(H:X.t) { measure X.cardinal S} :
> { R : X.t | forall x, X.In x R <-> X.In x S /\ ~X.In x H } :=
> ... (* same code as before *)
> Program Fixpoint then generates the appropriate proof obligations to
> show both termination and satisfaction of the spec.
> Two more remarks. First, I may very well be wrong, but your function
> looks like set difference, in which case it is already available as X.diff.
> Second, the "fold" operator over sets is a very good way to define
> functions that need to enumerate all elements of a set. It comes with
> a nifty induction principle in FSetProperties that allows you to prove
> properties in a fairly natural way.
> Hope this helps,
> - Xavier Leroy
I'm the kind of guy that until it happens, I won't worry about it. -
R.H. RoY05, MVP06
- [Coq-Club] Program Fixpoint and finite sets, David Pereira
- Re: [Coq-Club] Program Fixpoint and finite sets, David Pichardie
- <Possible follow-ups>
Xavier Leroy
- Re: [Coq-Club] Program Fixpoint and finite sets, Stéphane Lescuyer
- Re: [Coq-Club] Program Fixpoint and finite sets, Matthieu Sozeau
