- From: David Pichardie <david.pichardie AT inria.fr>
- To: David Pereira <dpereira AT liacc.up.pt>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Program Fixpoint and finite sets
- Date: Tue, 9 Nov 2010 11:39:51 +0100
Dear David,
Here is a solution using Function.
Note that Function fails to generate the right induction principle if you dont put H as a variable in a section before (beware that now S and H have been swapped). For your lemma, the fixpoint equation would have been enough but the powerfull induction principle generated by Function should helps
for more complex properties.
Hope this helps,
(* In a world-of-dream, the functionnality of Function and Program would be merged :-) *)
David.
Require Import FSetInterface.
Require Import FSetProperties.
Require Import FSetDecide.
Require Import Recdef.
Module FSetsProgram(X:FSetInterface.WS).
Import X.
Module Xp := Properties(X).
Module Xd := Decide(X).
Section H.
Variable H:X.t.
Function add_to_set_not_in (S:X.t) { measure X.cardinal S} : X.t :=
match X.choose S with
| None => X.empty
| Some x => if Xp.In_dec x H then add_to_set_not_in (X.remove x S)
else X.add x (add_to_set_not_in (X.remove x S))
end.
(* first obligation *)
intros S x Heq_anonymous i Hi.
apply X.choose_1 in Heq_anonymous.
rewrite <- (Xp.remove_cardinal_1 Heq_anonymous).
omega.
(* second obligation *)
omega.
Qed.
End H.
Import Xd.
Lemma teste : X.Equal (add_to_set_not_in X.empty X.empty) X.empty.
Proof.
assert (Aux:forall H S,
H [=] X.empty -> S [=] X.empty ->
X.Equal (add_to_set_not_in H S) X.empty).
intros H S.
functional induction (add_to_set_not_in H S); intros.
(* 3 simple cases are generated. Note we don't need the induction hypothesis here *)
fsetdec.
apply False_ind.
fsetdec.
assert (In x S) by (apply choose_1; auto).
apply False_ind.
fsetdec.
(* At last we use the auxiliary result to conclude *)
apply Aux; fsetdec.
Qed.
End FSetsProgram.
Le 8 nov. 10 à 18:19, David Pereira a écrit :
Dear all,
I am experimenting with Program Fixpoint feature of Coq for building functions on finite sets. I have implemented this simpl function [add_to_set_not_in], whose termination criteria was very easy to prove. The code is the following:
Import X.
Program Fixpoint add_to_set_not_in (S:X.t)(H:X.t) { measure X.cardinal S} : X.t :=
| None => X.empty
| Some x => match Xp.In_dec x H with
| left _ => add_to_set_not_in (X.remove x S) H
| right _ => X.add x (add_to_set_not_in (X.remove x S) H)
end
end.
Next Obligation.
symmetry in Heq_anonymous.
omega.
Defined.
Next Obligation.
omega.
Defined.
Proof.
admit. (* struck here *)
Qed.
End FSetsProgram.
I am currently struck in the lemma [teste], although it is a very simple property. Is there any standard tricks for reasoning about terms built using the Program Fixpoint construction?
Any help is very appreciated :)
Best reagards,
David.
- [Coq-Club] Program Fixpoint and finite sets, David Pereira
- Re: [Coq-Club] Program Fixpoint and finite sets, David Pichardie
- [Coq-Club] Binding variables within nested matches,
Ben Moseley
- Re: [Coq-Club] Binding variables within nested matches, Adam Chlipala
- <Possible follow-ups>
Xavier Leroy
Stéphane Lescuyer
- Re: [Coq-Club] Program Fixpoint and finite sets, Matthieu Sozeau
Stéphane Lescuyer
