- To: coq-club AT inria.fr
- Subject: [Coq-Club] Automatically attaching lemmas to definitions
- Date: Thu, 25 Nov 2010 11:51:18 +0100
Hey everyone, Is there a way to automatically bind/attach a lemma to a definition ? I will try to explain what I mean with that with a concrete example: Suppose I have a stream defintion s: CoFixpoint s : Stream A := x :: xs. Now I want coq to automatically generate the following lemmas: Lemma s_hd : A := hd s = x. Lemma s_tl : Stream A : tl s = xs. Obviously I would have to prove these lemmas. But assume that I have the tactics 'prove_hd' and 'prove_tl' that can prove the above lemmas fully automatically for any s,x and xs. So an example of this which is already in Coq is the generation of a new inductive type: Coq automatically generates the induction principle. I can imagine that the above is not directly possible on the already existing definition of Stream (because what I am asking should basically be a property of everything of type Stream). So I would also be content with having to define a new 'RichStream' type which has these properties. Such that I would have to define my stream using: CoFixpoint s: RichStream A := x :: xs. instead. Would something like this be possible ? Regards, -- - Frank |
- [Coq-Club] Automatically attaching lemmas to definitions, Frank Staals
- Re: [Coq-Club] Automatically attaching lemmas to definitions, Adam Chlipala
- Re: [Coq-Club] Automatically attaching lemmas to definitions, AUGER Cedric
