- To: AUGER Cedric <Cedric.Auger AT lri.fr>
- Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Automatically attaching lemmas to definitions
- Date: Fri, 26 Nov 2010 11:54:22 +0100
On 2010-11-25 16:09, AUGER Cedric wrote:
<snip>Ah I'm sorry for not being clear enough. I'm working a lot with streams so I defined "::" as the Cons constructor using Coqs notation facilities:
CoFixpoint s : Stream A := x :: xs.???
That doesn't mean anything:
I can assume that A is a Type, but
AFAIK "::" is for lists (not Streams)
I do not know what are x and xs (are they already been declared).
What is the aim of defining a (co)fixpoint which is not involved in its
definition?
Infix "::" := Cons (at level 60, right associativity) : richstream_scope.
Open Scope richstream_scope.
In the above definition 'x' and 'xs' can be arbitrary terms, possibly again depending on 's'. I simply wanted to name the head and the tail. The 'real' definitions can be any stream definition.
A nice example would be the following definition of the naturals. Unfortunately Coq cannot verify the guardedness of this definition.
CoFixpoint nats : Stream nat := 0 :: map S nats.
An other example is a definition of even. A function that takes a stream and retains only the elements on even indices.
CoFixpoint even(t: Stream A) : Stream A := hd t :: even (Str_nth_tl 2 t).
In both these examples the head (our term 'x') and the tail (our term 'xs' ) can be some complicated term, possibly again depending on 's'. Hence we have a CoFixpoint. However, no matter what these terms look like the following two lemmas can be proven[1] (again using the generalized 's','x','xs' notation, and this time in the correct Coq syntax):
Lemma s_hd : hd s = x.
Lemma s_tl : tl s = xs.
[1] Note that in the case 's' is a function (like in the case with even) the lemma would become a bit more elaborate as the input variables would have to be universally quantified:
Lemma even_hd : forall t: Stream A, hd (even t) = hd t.
I do not know if "Function" and "Program" can manage coinductive types,From what I can see in the documentation both require some decreasing argument, which is unavailable in case of streams. I am affraid that extending them is out of the scope of my project.
(if I well remember they require measure, so it shouldn't be the case);
if not, maybe would it be a good idea to extend it for your purpouse.
This seems/seemed interesting. But I think this is no longer possible when 'x' and 'xs' are dependent on 's'. Or am I missing something.
One last thing, you can use simply sigma types
For instance:
Record Cons_spec (A: Type) (x: A) (xs: Stream A): Type :=
{ s: Stream A;
s_hd: hd s = x;
s_tl: tl s = xs
Definition ConsRich: forall A x xs, Cons_spec A x xs
:= {|s := Cons x xs; s_hd := _; s_tl := _|}.
Proof.
abstract prove_hd. (* since you tell you have such tactic *)
abstract prove_tl. (* since you tell you have such tactic *)
Defined.
Now you have the following:
(ConsRich A x xs).(s_hd A x xs): hd (ConsRich A x xs).(s A x xs) = x
and
(ConsRich A x xs).(s_tl A x xs): tl (ConsRich A x xs).(s A x xs) = xs
I hope I gave you some good idea(s)Thanks for your input.
Regards
Regards,
- Frank
- [Coq-Club] Automatically attaching lemmas to definitions, Frank Staals
- Re: [Coq-Club] Automatically attaching lemmas to definitions, Adam Chlipala
AUGER Cedric
- Re: [Coq-Club] Automatically attaching lemmas to definitions, Frank Staals
