coq-club - Re: [Coq-Club] Automatically attaching lemmas to definitions
chronological Thread
  • To: Frank Staals <f.staals AT student.tue.nl>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Automatically attaching lemmas to definitions
  • Date: Thu, 25 Nov 2010 08:31:09 -0500
Frank Staals wrote:
Hey everyone,
Is there a way to automatically bind/attach a lemma to a definition ? I will try to explain what I mean with that with a concrete example: Suppose I have a stream defintion s:
CoFixpoint s : Stream A := x :: xs.
Now I want coq to automatically generate the following lemmas:
Lemma s_hd : A := hd s = x.
Lemma s_tl : Stream A : tl s = xs.
These last two lines don't make sense as Coq [Lemma] commands, but that's probably just a typo.
In general, what you ask about is possible but not easy, using a mix of two metaprogramming methods:
1) The traditional "dynamically-typed" approach, where you write syntax-manipulating code in an OCaml plugin. This probably requires at least a few days familiarizing yourself with the Coq code base (which means, at best, reading .mli files, not some separate documentation [and you also need to figure out the structure of the code base on your own, to know which .mli files to read]).
2) Proof by reflection, which can be implemented entirely in normal Coq code, but can be trickier (though easier to know when you have implemented correctly, thanks to expressive Gallina type-checking). Especially when a metaprogram analyzes an inductive type definition, it is usually convenient to pair reflection with some amount of OCaml plugin code, to reify some plugin-specific class of syntax. For a quick introduction to proof by reflection in Coq, you can see Chapter 10 of CPDT (http://adam.chlipala.net/cpdt/).
This tech report might also be of interest:
    http://adam.chlipala.net/papers/AutoSyntaxTR/
It describes an old system for generating standard theorems automatically about inductive definitions of syntax trees with de Bruijn indices.
Perhaps the most useful summary answer is that you would have to go down a significant rabbit hole to implement what you want. Whether this is worthwhile depends on your interests, how often you want to use this functionality, and how big the examples are.
