coq-club - Re: [Coq-Club] blocked in an elementary proof
chronological Thread
  • From: Petar Maksimovic <petar.maksimovic AT gmail.com>
  • To: Daniel de Rauglaudre <daniel.de_rauglaudre AT inria.fr>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] blocked in an elementary proof
  • Date: Sun, 12 Dec 2010 18:48:30 +0100
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :cc:content-type:content-transfer-encoding; b=HXkrmxFaN//cRi0q1fJWemjxUW5V2o/iytapu9D/LS9dzpkpeSAVxzrGr6/3JTNUM7 +0DNb5zxviBeh7/X0KOyt+W+3Z/qHjdWZdulYK2ZppP1ej1NCcsxV3Uyi81PgaMfh2ai 0Tyo4oYN7cNkCDK5R8hugxZ8kRjtMk/03wtZw=
Hi Daniel,
You could actually prove directly that your sum function is always
equal to 'plus' on natural numbers. From this, you'll have no problem
proving your lemma.
Require Import Arith_base.
Fixpoint sum (a b : nat) : nat :=
 match b with
 | 0 => a
 | S b1 => sum (S a) b1
end.
Lemma sum_plus : forall b a : nat, sum a b = a + b.
Proof.
induction b.
(* Base case *)
auto.
(* Induction step *)
intro a.
simpl.
rewrite (IHb (S a)).
rewrite plus_Snm_nSm; reflexivity.
Qed.
I'm not that well versed in Coq to discuss a minimum condition for the
proof you wanted to do, but it seems to me that a stronger induction
hypothesis might be required, and you can obtain it as above.
Best regards,
Petar
On 12 December 2010 18:17, Daniel de Rauglaudre
 wrote:
> Hi everybody,
> I am a beginner in Coq and I am blocked in that proof:
>    match b with
>    | 0 => a
>    end.
>  Lemma sum_zero : forall a : nat, sum 0 a = a.
> This 'sum' could be a definition of the 'plus' on natural numbers.
> It seems to be true but I have no idea how to complete my proof.
> I managed this:
>  intro a; elim a; [ simpl; reflexivity | clear a; intros n H ].
> I could add 'simpl', but I see no way to continue.
> Perhaps recursion on 'a' is not the solution, but I don't see other
> ways.
> Well, actually, I am not sure I can proof it 'by hand' without using
> other definitions of addition and subtraction, this may be the problem.
> I would like to know what is *minimum* to complete such a proof.
> Any hints?
> http://pauillac.inria.fr/~ddr/
