- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] blocked in an elementary proof
- Date: Sun, 12 Dec 2010 19:17:53 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=vermaat.name; h=subject:from :reply-to:to:in-reply-to:references:content-type:date:message-id :mime-version:content-transfer-encoding; q=dns; s=vermaat.name; b=RPq1k4ajQo7PGCvj4aZs8LUJp9A4okkJxDBW7exnzI+1cEE+ZNvuJjnr2mdrh EnzskdvhRbX11KjWlEnk3XCc/0yw3Uq8ZideCBPTqDL8auZEf0IN6UEoGz6h6kfp IDEoT8xJysaPoyzzqihy+Q6ElvFAWSS9hkXqHTCOXIKm7M=
> Fixpoint sum (a b : nat) : nat :=
> match b with
> | 0 => a
> | S b1 => sum (S a) b1
> end.
> Lemma sum_zero : forall a : nat, sum 0 a = a.
I think the most obvious way is by first proving the following fact:
Lemma sum_S : forall a b : nat, sum a (S b) = S (sum a b).
From this it is actually quite easy to prove sum_zero.
cheers,
Martijn
- [Coq-Club] blocked in an elementary proof, Daniel de Rauglaudre
- Re: [Coq-Club] blocked in an elementary proof, Petar Maksimovic
- Re: [Coq-Club] blocked in an elementary proof, Martijn Vermaat
- Re: [Coq-Club] blocked in an elementary proof, Stéphane Lescuyer
- Message not available
- Re: [Coq-Club] blocked in an elementary proof, Daniel de Rauglaudre
- Re: [Coq-Club] unblocked, thanks!,
- Re: [Coq-Club] unblocked, thanks!, Jean-Francois Monin
- Re: [Coq-Club] unblocked, thanks!, quentin . carbonneaux
- Re: [Coq-Club] unblocked, thanks!, AUGER Cedric
